Carb rebuild - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 1 (permalink) Old 06-19-2016, 05:03 PM Thread Starter
Carb rebuild
I recently rebuild both carbs on my '99 Vulcan. It starts up so much easier now, like it should and runs smoothly. After disassembly, I found the float needles were not sealing and the external cut-off valves were leaking gas. Here are the vendors I used for the parts.
Kawasaki VN700 VN750 Vulcan Economy Carburetor Carb Repair Rebuild Kit | eBay
2 Air Cut Off Valves Kawasaki EL250 EX250 Ninja VN700 VN750 VN1500 Vulcan | eBay
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
