Universal fuel tank cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 06-18-2016, 12:31 AM Thread Starter
Do any of you knows of a universal fuel tank cap that will fit a 1986 vulcan 750? Thank you in advance.
poncho26 is offline
post #2 of 6 (permalink) Old 06-18-2016, 12:50 AM
Look on eBay for a stock one
post #3 of 6 (permalink) Old 06-18-2016, 01:39 AM Thread Starter
i found many but i dont know which will fit the actual diameter of the hole.
poncho26 is offline
post #4 of 6 (permalink) Old 06-18-2016, 01:43 AM
Your best bet is stock.easiest anyway.
post #5 of 6 (permalink) Old 06-18-2016, 09:45 AM
I agree with Doc, stock is the way to go.
I looked in the past for a replacement, and even tho there may have been some that fit the hole, I would have had to deal with the area around it where the stock one mounts.. its recessed, and has 2 holes (for the screws that hold it) that pass all the way thru the skin. they would have to be plugged/filled to prevent rain/bugs from getting in, and keep fuel and fumes inside
I picked up a used one, with key, from a member here for a good price when I needed one. make sure you get one with a key (if possible) to avoid re-keying it to fit your ign key
michiganteddybear is offline
post #6 of 6 (permalink) Old 06-18-2016, 02:33 PM
Expendable newbie
evulcannibal's Avatar
Don't mean to thread jack here, but is the CA gas cap interchangeable with other non CA gas cap. I'm guessing no, but I just wanted to confirm. This is just strictly for my knowledge, in case I need to know it for the future.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
