Gas cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 2 Post By WilliamTech
post #1 of 5 (permalink) Old 06-14-2016, 02:46 PM Thread Starter
Gas cap
Hey all! I just got a 1986 vulcan 750 a a kz550 Ltd, but the gas cap on the 750 won't open with the key I think is seized can someone recomend a method to get it loose again or if not possible how to remove and where to get a replacement?
Thank you in advance.
poncho26 is offline
post #2 of 5 (permalink) Old 06-14-2016, 08:30 PM
With a pin punch (or substitute tool), CAREFULLY knock out the hinge pin.....for complete cap removal.
Repair lock or have re-keyed as necessary......
Mike DeAngelo and poncho26 like this.
post #3 of 5 (permalink) Old 06-14-2016, 08:35 PM Thread Starter
Thank you William tech you just saved me a lot of work.
poncho26 is offline
post #4 of 5 (permalink) Old 06-15-2016, 11:10 AM
Expendable newbie
evulcannibal's Avatar
If you're a psycho and just happen to own a Captive Bolt Pistol, then you can punch out that lock like how the bad guy in No Country for Old Men did.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #5 of 5 (permalink) Old 06-18-2016, 12:23 AM Thread Starter
Thank you evulcanibbal but rather punched it out with another pin, I didn't have any luck fixing the seized lock is there a universal cap I can use instead?
poncho26 is offline
