No choke - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-06-2016, 11:07 PM Thread Starter
LOTTO's Avatar
No choke
The bike I bought is missing the choke cable wondering if anyone has done Frame mounted mod to their vn to get the thumb choke off the handle bars if so I'd like to see how it turned out
LOTTO is offline
post #2 of 14 (permalink) Old 06-06-2016, 11:56 PM
Sorry, I do not know of anyone attempting this idea....
post #3 of 14 (permalink) Old 06-07-2016, 11:28 PM
Chasin' the blacktop
Spencer1's Avatar
Having the choke on the handlebars is much easier to use on a cold morning than a frame mounted choke.
North Georgia
Spencer1 is offline
post #4 of 14 (permalink) Old 06-08-2016, 12:15 AM
A ham sandwich walks into a bar.the bartender says sorry we don't serve food here.no joke...er... choke
post #5 of 14 (permalink) Old 06-08-2016, 11:20 AM
Expendable newbie
evulcannibal's Avatar
Then the ham sandwich says, forget this bar, I'm more of a club sandwich anyways and took the subway home.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #6 of 14 (permalink) Old 06-08-2016, 12:31 PM
Lol nice
post #7 of 14 (permalink) Old 06-08-2016, 01:27 PM
Expendable newbie
Are you only missing the cable? Are all the pieces on the choke plunger still there, like the fork levers, springs, and little metal bar between the two carbs. If so, then maybe you can just manually push the plunger lever out and in. I think you can see and reach the choke lever plunger on the left side by the petcock. It might take a little bit of pressure, but you should be able to push it in and out with your finger or a hard piece of metal like a key. Or you can weld or install a metal stick in there and pull the stick for easier use.
95 VN750
Blacked out engine
Gear indicator
post #8 of 14 (permalink) Old 06-08-2016, 01:48 PM Thread Starter
LOTTO's Avatar
Cable is all it needs jacka$$ I got it from cut the cable when he removed the carbs
Was thinking of doing a frame mount like the one on my vn800 classic but I went ahead and ordered the cable instead.
LOTTO is offline
post #9 of 14 (permalink) Old 06-08-2016, 04:14 PM
Expendable newbie
Iím guessing that jackass remark was directed at me. I was merely offering you an alternative to using the choke cable, since you said you were missing the choke cable and no one had done the mod of which you speaketh.
Well I sir, for one will not stand here and be called a jackass. A dumbass maybe, but not a jackass. You have insulted my honor, I demand satisfaction. (Glove slap!!!) I challenge you to a duel.
95 VN750
Blacked out engine
Gear indicator
post #10 of 14 (permalink) Old 06-08-2016, 05:48 PM Thread Starter
LOTTO's Avatar
Umm hahaha insert a period between needs and jacka$$
Dang run on sentences
LOTTO is offline
