part#/$/vendor: Iridium plugs, caps, wire - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 26 (permalink) Old 09-05-2008, 12:50 PM Thread Starter
Cool part#/$/vendor: Iridium plugs, caps, wire
current info that may be helpful...
From the nkg site/search
2006-1986 KAWASAKI VN750-A 750
Spark Plug Part No. Stock No. Plug Gap
Iridium DPR7EIX-9 7803 0.035
vendor
BikeBandit.com
NGK PLUG DPR7EIX-9 (4/BX) price each $7.79 $31.16
Subtotal:$31.16 Shipping & Handling:$7.95 ups ground Total:$39.11
denniskirk.com
2 Part# 20789 NGK Spark Plug Cap/LD05FP Type: Plug Cap
Units: Each 0.12&nbsp Lbs. $2.50 $5.00
2 Part# 20306 XD05F Spark Plug Cap Type: Plug Cap
Units: Each 0.24&nbsp Lbs. $3.30 $6.60
1 Part# 2021 Spark Plug Wire Type: 7mm Plug Wire - Universal Units: Each 4.75&nbsp Lbs. $2.95 $2.95
Total Weight: 5.11 Lbs. Order Subtotal: $14.55 Shipping: $6.95
Order Total: $21.50
jmczzz is offline
post #2 of 26 (permalink) Old 09-05-2008, 01:07 PM
ExNewbie..Still Learnin'!
rsawyer's Avatar
JMC - Very helpful, thanks!
'89 Vulcan 750
VROC# 30232
HID Headlamp Conversion
V&H Cruzers (great sound)
Kaw V-Force Windshield
Kaw Rear Luggage Rack
Kaw Engine Guard
VN750.COM Grill Cover
W&M Black Magic Saddlebags
Diehard M/F Battery
R/R Replaced/Relocated
Stator Replaced
Voltmeter Installed
Splines Lubed
Metzler 880 Marathons
Front - 110/90-19
Rear - 170/80-15
Carbs Balanced
Carb Mix Adjusted
Fuel Tank Derusted/Lined/Sealed
NGK Iridium Plugs
rsawyer is offline
post #3 of 26 (permalink) Old 09-05-2008, 03:03 PM
A10 Pilot
mkonops's Avatar
I found a set of four plugs on eBay for 35 shipped. Got them from ebay user: kxf250-06
VN750 A10
mkonops is offline
post #4 of 26 (permalink) Old 09-05-2008, 04:01 PM
Scootergptx's Avatar
I posted in another thread about AutoZone giving me the wrong plugs. Took them back and they just did an even exchange. Didn't dawn on me till I read the part numbers here that they sold me a 2 dollar spark plug and exchanged them for the iridiums.
Suddenly I'm not so upset I had to make the trip back up there.
Scootergptx is offline
post #5 of 26 (permalink) Old 09-05-2008, 04:05 PM
They cost only $28.00 a set at Autozone..if you use give them the stock number.
They come in a four pack for $6.99 each. If you just try an order them seperately they are like $8.99 each.
FYI
post #6 of 26 (permalink) Old 09-05-2008, 10:14 PM
A10 Pilot
mkonops's Avatar
I read on here about Autozone, but I went to two semi-local locations and neither carried the P/N I needed. Oh well.
VN750 A10
mkonops is offline
post #7 of 26 (permalink) Old 09-05-2008, 10:39 PM
Mine did not have it either, but ordered them. It only took one day to get there.
EDIT:
Oh, and this info is in the Verses:
"Just thought I'd mentioned this as it might save someone a few bucks. There was a discussion on the group a little while go about these plugs (DPR7EIX-9) and where to get them. The internet lowest price was around 7 bucks plus shipping. I decided to get some before the Gathering and thought I'd try locally to save the shipping. I looked on the net at the chains here locally (Autozone, O'Reilly's, and Advance Auto) and they were all around 10.xx or so. In talking to Dan Tadrick of the group he mentioned he had them and the part number is 7803. Well, if you search for DPR7EIX-9 at the Advance Auto site is comes back at 10.99. However if you put in just 7803, you get several things with the same part number, but one of them is the NGK plug for only 6.96. What's up with that? Anyway, I went to the local Advance store and it is the same plug. So if you happen to have an Advance store nearby (mostly east and some in the midwest), the price is as low as the internet without the shipping...."
post #8 of 26 (permalink) Old 09-05-2008, 11:10 PM Thread Starter
Thanks for all the input on the plugs. But are the plug caps and the 7 mm plug wire the best and correct buy. the wire comes as a 72 inch roll BTW.
jmczzz is offline
post #9 of 26 (permalink) Old 09-05-2008, 11:17 PM
I believe 750Doug anwsered that here:
https://www.vn750.com/forum/showthread.php?t=8486
Not really sure what would be "best" however...as long as they do their job I'm happy.
post #10 of 26 (permalink) Old 09-06-2008, 12:19 AM Thread Starter
yes you're right. I just have read many threads and found that sometime there are several different opinions. Some of the verses are a bit dated and somtimes part nums, vendors etc. change.
I wanted to see if any new or previously unknown (by me) info emerged.
"best" was ment to be the parts that most have had good results with.
Thanks for your help.
jmczzz is offline
