Carb questions.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By OleDirtyDoc
post #1 of 7 (permalink) Old 05-14-2016, 01:33 AM Thread Starter
Carb questions....
The vulcan I recently acquired has k&not air filters and I gutted the exhaust....she seems to run fine...it had the filters I it when I got it...I assume the carbs have been jetted as she winds up good...I have 142-42 jets in them...is that stock? Also,I had a pop on deceleration, I put marbles in the hose coming off the "ears" ....popping gone...is there anything else I should do? Thanks.
Fallguy666 is offline
post #2 of 7 (permalink) Old 05-14-2016, 01:58 AM
Disclaimer here, I am no carb specialist, but the 142-42 jets seem
a bit rich to me. The Clymer manual has the stock main jet as a 132, and the pilot jet as a 38.
Of course with the mufflers gutted, you have greatly diminished back pressure, so you probably need a richer mixture to avoid burning the valves.
Now I will let the carb gurus tell you what you really want to hear.
post #3 of 7 (permalink) Old 05-14-2016, 02:19 AM Thread Starter
Would be my guess they were jetted for the air filters....this bike was also rode and tuned in Hawaii if that matters.....spent it's entire life there
post #4 of 7 (permalink) Old 05-14-2016, 03:45 AM
1100 feet.degoated.screaming eagle mufflers with almost no baffle.earshaved with k&n pods.140/42 jets.2 shims under needle.runs like a raped ape on meth
Gaz73 likes this.
post #5 of 7 (permalink) Old 05-14-2016, 08:47 AM
Well many might have different opinions on your jetting, but all that matters is....
What do your plugs look like?
And
How does it run?
If the plugs aren't fouling, and the bike runs good....nothing more to say.
post #6 of 7 (permalink) Old 05-14-2016, 06:10 PM Thread Starter
Could have a little more pep I think.she runs fine.plugs are a little dark.haven't been able to do a plug chop yet.with the marbles in,do I need to put a crank case breather on?
post #7 of 7 (permalink) Old 05-19-2016, 12:45 AM Thread Starter
Anybody know if I need to run breathers since I did the marbles?
