Help with hooking up throttle cables - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 23 (permalink) Old 04-28-2016, 12:51 PM Thread Starter
I'm having difficulties figuring out a way to hook the throttle cables back up to the carbs. The throttle is no problem, but the deceleration cable is tricky because it's tucked way back, can anyone give me some guidance? 98 VN 750
Nightowl is offline
post #2 of 23 (permalink) Old 04-28-2016, 01:21 PM
calebj's Avatar
I'm assuming you're doing this with the carb assembly off the bike? If not, that's the only way I know to do it.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 23 (permalink) Old 04-28-2016, 01:49 PM Thread Starter
Ummmm no. The carb assemble is most definitely back on the bike and the boots to the cylinders are hooked back up so I can't see myself going through that again. I hooked the choke cable up before reinstalling carbs though.
Nightowl is offline
post #4 of 23 (permalink) Old 04-28-2016, 02:00 PM
calebj's Avatar
Interesting. The manual makes it sound like this is possible, but they definitely have you reconnect them before carburetor installation when you're taking the carbs off and on, and I assume that's because it's so difficult to do with them in place. Good luck!
1999 EN500 32k
calebj is offline
post #5 of 23 (permalink) Old 05-13-2016, 10:40 AM
Probably not much help at this point but I work on a lot of different bikes. Inline 4's, 2's singles even Goldwings and in every instance you remove and install throttle cables with the carbs not installed. Sorry.
jdvorchak is offline
post #6 of 23 (permalink) Old 05-13-2016, 01:42 PM
What year wings did ya play with?I've got a 79 and an 80
post #7 of 23 (permalink) Old 05-13-2016, 01:52 PM
Well unless you removed the cables before you removed the carbs, you didn't follow the golden rule of assembly...." Install in the reverse order of removal"
So yeah, it's a "doh"...a big one I'm afraid....
post #8 of 23 (permalink) Old 05-15-2016, 09:31 AM
I owned 3 GL1200s, 2-84's and an 85. I have helped other guys with their 1000 and 1100's. The 1200's did away with the split plenum so they are in my opinion easier and less complex. The carbs themselves are more modern/conventional CV design and syncing seems easier as the idle screws don't seem to move much once you set the screw and tighten the jam nut. But a carb is a carb to me. From Holley double pumpers and Carter down to weed eaters and everything in between.
post #9 of 23 (permalink) Old 05-15-2016, 05:34 PM
Gotta pull the carbs back off the 1100.cleaned them and now number three is leaking out the bowl.love the way these motors feel under power, though
post #10 of 23 (permalink) Old 05-15-2016, 05:39 PM
Jdvorchak,do you know if the front exhaust pipes off a 1200 bolt to the 1100 heads?am thinking up a custom exhaust and don't want to chop up a stock gl1100 exhaust($$$)
