Help with hooking up throttle cables - Page 2 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #11 of 23 (permalink) Old 05-15-2016, 08:28 PM
Concert connoisseur
wib714's Avatar
do the deceleration or push first then the acceleration. I did mine three times the other day. I installed the carbs on the left side hooking the choke up first, buttoned up the carbs then installed the cables. it can be done
Jb87 likes this.
1986 vn 750 aka "Huck Farley"
42,000 miles
Rick's stator and rr
Tuxedo stator cover mod
pickup coil mod
dampers replaced
agm m/f battery
Hid conversion
NGK Iridium spark plugs
wib714 is offline
post #12 of 23 (permalink) Old 05-17-2016, 01:18 AM
Jdvorchak,do you know if the front exhaust pipes off a 1200 bolt to the 1100 heads?am thinking up a custom exhaust and don't want to chop up a stock gl1100 exhaust($$$)
Pretty sure they don't. Check out the naked goldwings forum and ask there. I'm very active there and lots of guys do mods. Post your question in the tech forum.
GoldWing Tech Discussions - NGWClub®, Inc.
jdvorchak is offline
post #13 of 23 (permalink) Old 05-17-2016, 10:34 PM
Will join.have lurked there a little. Thank you.are you under the same screen name?
OleDirtyDoc is online now
post #14 of 23 (permalink) Old 05-18-2016, 08:52 AM
You only need the acceleration cable. And it is REAL easy to install. I've been running mine with only one cable for tens of thousands of miles with no problems. The decel cable was supposed to be a safety device, but can actually make things worse if it sticks or binds. Just use the acceleration cable (the one that opens the throttle) and keep it well lubed.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #15 of 23 (permalink) Old 05-18-2016, 09:57 AM
Yes jdvorchak. Hope to see you on the NGW site.
post #16 of 23 (permalink) Old 05-18-2016, 09:59 AM
Note that Kawasaki only started using that Push cable when Fed regulations dictated it. None of my inline 4 Kawi's have that push cable. Only the pull cable. I was hesitant to mention that being a new member here.
post #17 of 23 (permalink) Old 05-18-2016, 12:21 PM
No way!!!an area on your bike that isn't how the fine engineers at Kawasaki designed it?say it isn't so.
post #18 of 23 (permalink) Old 05-19-2016, 09:42 AM
As everyone knows, there are many things on the VN750 that weren't properly engineered, like no stator access, the balancer system, the cam chain tensioners, even the flimsy toolbox door.
I have two Yamaha XT225s. a 1994 model that I ride, which only has one throttle cable, and a nearly complete 2001 parts bike (with a 3000 mile motor) that has 2 throttle cables. I'm inclined to believe this is due to more govt meddling in a place that definitely does not need it. Someday ABS will be mandatory, then crash avoidance systems, and finally complete computer control of the bike, making the rider useless other than to just set there and enjoy? the ride.
Just about everybody here has seriously modified their bikes, so I don't see an issue. With a properly lubricated acceleration cable in good condition, and no decel cable, the throttle will feel a lot better, and be easier to control. And it will snap closed easily when released.
1979 Vespa P200E
post #19 of 23 (permalink) Old 05-19-2016, 11:20 AM
Jerry just busting your chops,hence the
post #20 of 23 (permalink) Old 05-19-2016, 12:48 PM
Question to anyone who has done this, did you remove the decel cable altogether, or just rig it up somewhere out of the way?
jkanclark is offline
