What is name/function of this carb assembly - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 8 (permalink) Old 04-27-2016, 09:38 PM Thread Starter
What is name/function of this carb external plunger\spring
Is it possible to delete a misfired thread I started accidentaly?
Got stuck for a while tonight after cleaning out and rebuilding carbs. Moral of the story .. take many pictures of things BEFORE you take apart. Don't assume a diagram will be all you need in the manual
In my case the coil spring orientation caused grief and searching was difficult without naming part name
ID:	31497   Click image for larger version
gidaeon is offline
post #2 of 8 (permalink) Old 04-28-2016, 01:35 AM
Click image for larger version Name: image_1461807448170.jpg Views: 6 Size: 85.1 KB ID: 31497 Click image for larger version Name: image_1461813390481.jpg Views: 6 Size: 82.6 KB ID: 31505
"ATTACHED THUMBNAILS" NOT AVAILABLE !
post #3 of 8 (permalink) Old 04-28-2016, 07:53 AM Thread Starter
Yeah, Im having problems with my attachments not displaying will search tech forum later today.
Not sure if uploaded attachments count as my 10 allowed uploads or not.
gidaeon is offline
post #4 of 8 (permalink) Old 04-28-2016, 08:12 AM
calebj's Avatar
Choke plunger assembly? It caused me no end of grief, because spatial relations is not my thing. Couldn't turn the parts around in my head to figure out how everything lined up.
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #5 of 8 (permalink) Old 04-28-2016, 05:08 PM Thread Starter
Indeed! Once I found a properly angled picture all was well, took some time without knowing parts name.
I will say spending 6 hours with a carb you get to know it much better haha.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #6 of 8 (permalink) Old 04-28-2016, 05:56 PM
Expendable newbie
evulcannibal's Avatar
[QUOTE=gidaeon;1079761... Moral of the story .. take many pictures of things BEFORE you take apart. Don't assume a diagram will be all you need in the manual
In my case the coil spring orientation caused grief and searching was difficult without naming part name[/QUOTE]
For me I took a bunch of pictures, but I had lost those exact pieces you have in your hand. I ended up going to the motorcycle junk and getting the pieces there. Moral of the story for me, take better care of the pieces you pull off, especially small pieces.
Don't take my word for it. I'm just a foolish newbie.
When in doubt, just know that I am only joking around.
95 VN750
Top speed is 112 mph at ~7900 rpm
Blacked out engine
Dry rusty splines finally lubed for the first time
R/R relocated to the side of fuse box
Rust removed from tank
In line fuel filter, 23-28 micron rating
Gear indicator
LED turn signals & brake light
16 color LED engine light up & underglow
evulcannibal is offline
post #7 of 8 (permalink) Old 04-28-2016, 06:06 PM Thread Starter
Yes! Also, when you have boxes and baggies available 2ft away and don't use them and loose a piece into the abyss underneath work bench you will not be proud of yourself.. and no one else will care how sad you feel haha.
How many trips have I made to hardware stores or ordered small fasteners due to lack of immediate storage?
2002 vn750
40/138 jetting
gidaeon is offline
post #8 of 8 (permalink) Old 04-28-2016, 06:27 PM
Expendable newbie
The sad thing is that you don't really learn your lesson and you do the same thing and wouldn't you know it, you've done gone lost the damn pieces the same way you did before.
95 VN750
Blacked out engine
Gear indicator
