tw200 petcock barb fitting too small for 5/16 or metric hoses - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 04-17-2016, 12:19 AM Thread Starter
So I didn't anticipate the oem yamaha tw200 petcock would have a smaller barb fitting (1/4" equivalent in english)
Did you guys do something to step up or adapt from the 1/4" when going to your t fitting and later 5/16 or the metric hoses to carbs? Or did you replace the barb that is pressed into the tw200?
I briefly wondered about drilling the tw200 to use the 1 barb fitting from the original petcock but don't have metric bits and didn't want to ruin the new part.
I am sure there is a simple solution I am missing here and will feel dumb about
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 3 (permalink) Old 04-17-2016, 12:28 AM
Your 5/16" fuel line is incorrect size.
You may have it clamped on the carb's w/o leaking........ but ? ? ?
1/4" is proper for Fuel Line.
I utilize Clear ¼ “ Fuel Line and 3/16 “ Vacuum Line - - w/o clamps (stretches for tight connection)...
hope this helps....
post #3 of 3 (permalink) Old 04-17-2016, 10:25 AM Thread Starter
hope this helps....
Ok, didn't realize 1/4 couldfit the carbs. Knifemaker was clear 5/16" is the size to use and the oem metric hose is clearly bigger than 5/16.
Wouldn't you know I had all the rights parts to switch over prior and returned them all..
I'm a little too ocd to not put clamps on even tight fittings ha
2002 vn750
40/138 jetting
gidaeon is offline
