Q for those who have ear shaved.... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 08-21-2008, 12:38 PM Thread Starter
750Doug's Avatar
What did you do with the end of the vent line that is supposed to be plugged into the back of the RH airbox?
750Doug is offline
post #2 of 11 (permalink) Old 08-21-2008, 01:19 PM
In the center of your frame under your tank where the frame V's, there is a section of frame you can access (spine). My hose lays perfectly in there. No wind disterbence.
post #3 of 11 (permalink) Old 08-21-2008, 01:24 PM
I plugged a small lawn mower air filter on it and shoved it up under the fuel tank. I am not really sure that a filter is needed. It did not have one before, I don't guess one is needed. I am leaving mine on anyways.
post #4 of 11 (permalink) Old 08-21-2008, 02:04 PM
EMGO filter bolted where the air box was.
2001 VN750
16k miles
Ear Shave & Coastered
EMGO & UNI Filters
Kuryakn ISO Grips
Stebel Nautilus Air Horn
Clear Alternatives LED Tail Light
TOC MCCT
AGM Battery
Custom Footpegs
LED Voltmeter
tilak is offline
post #5 of 11 (permalink) Old 08-21-2008, 02:11 PM
He is talking about the carb vent hose that goes to the right side ear.
post #6 of 11 (permalink) Old 08-21-2008, 02:36 PM
Isn't that what he's asking about? If not, where does the one he's referring to connect? Thx.
2001 VN750
16k miles
EMGO & UNI Filters
Kuryakn ISO Grips
TOC MCCT
AGM Battery
Custom Footpegs
LED Voltmeter
tilak is offline
post #7 of 11 (permalink) Old 08-21-2008, 02:46 PM
I used the emgo filter on the engine vent hose and had bolted it to the ear bolt. But I was conserned about water, so this hose I also shove up under the fuel tank.
post #8 of 11 (permalink) Old 08-21-2008, 02:50 PM Thread Starter
750Doug's Avatar
In between both carbs is a "TEE'd" vent line that runs over to, and plugs into the right side airbox. If this tube is left out in the open, when riding, moving air can get forced into it and cause the bike to bog down/miss/hesitate etc.
Shaving the ears means pulling out the airbox and leaving the end of that vent line exposed, since it has nowhere to be plugged into now.
So I wondered what people did with the line to avoid the air ingestion issues, since they removed the air box for the shave. Where did they move the end of the vent line to....
Clear as mud?
Oh, and thanks for all the replies.
750Doug is offline
post #9 of 11 (permalink) Old 08-21-2008, 05:02 PM
Clear as mud?
LMAS... It's funny how something so straight forward can be so confusing!
post #10 of 11 (permalink) Old 08-21-2008, 05:43 PM
Chucklehead
dragon159's Avatar
Mine is the same place as Kanuck's, in the back bone. Just seemed to be the best place for it.
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
