Vacuum cap size for carb vacuum\petcock port? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 11 (permalink) Old 04-13-2016, 04:08 PM Thread Starter
I realize the vaccum port to petcock would be metric. But I need to plug it with a sae size plug for tw200 conversion.
Are you guys using 5/16? 1/4? different? My eyeball guesstimates aren't that great, and I don't have access to carb for a few days.
gidaeon is offline
post #2 of 11 (permalink) Old 04-13-2016, 07:27 PM
Fuel hoses are 5/16 ID.
post #3 of 11 (permalink) Old 04-13-2016, 07:38 PM
calebj's Avatar
He's asking about the vacuum cap. I think I have one in the garage, I'll try to find it and confirm.
calebj is offline
post #4 of 11 (permalink) Old 04-13-2016, 07:46 PM
I utilize clear Line purchased off Reels from True Value Hardware store.
EDIT: This is not Fish Tank Air Line/Hose !
Clear is nice for fuel flow observation (when-ever needed).
..... is flexible for routing...stretches over nipples, No clamps required
Clear Fuel Line 3/16 Vacuum Line
enjoy
post #5 of 11 (permalink) Old 04-13-2016, 07:47 PM
RoadHopper's Avatar
So. . . how long do you want it to be not working in its old role correctly?
RoadHopper is offline
post #6 of 11 (permalink) Old 04-13-2016, 07:54 PM
calebj's Avatar
Clear ? Fuel Line 3/16 ? Vacuum Line
enjoy
I finally stopped using clear because it always hardened, yellowed, and usually requiredrequired clamps. Yours doesn't yellow and harden?
calebj is offline
post #7 of 11 (permalink) Old 04-13-2016, 08:00 PM
I have had it on there for 3+ (?) years..... I need to look at it ! LOL
post #8 of 11 (permalink) Old 04-13-2016, 08:27 PM Thread Starter
Sorry i was not clearer - im capping off the CARBs vacuum port of course, not the oem petcock since its being removed ;-)
I got a brief peek and 5/16 is definitely too big. It must be 3/16 or 1/4 to seal and stay on.
RoadHopper likes this.
gidaeon is offline
post #9 of 11 (permalink) Old 04-13-2016, 10:31 PM
calebj's Avatar
I measured about .21 inches. Try 5mm or 3/16 for a vacuum cap.
calebj is offline
post #10 of 11 (permalink) Old 04-13-2016, 10:42 PM Thread Starter
You are the man! Does it matter if I get the thick rubber ones or the thinner vinyl looking. the auto stores I see have both styles I assume it doesn't matter?
List: Vacuum Caps | O'Reilly Auto Parts
wasn't sure if gas ever works its way "out" of the part and could degrade a cap
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
