Petcock making high pitched noise in "on" reserve" - diaphram failure? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 5Likes
post #1 of 12 (permalink) Old 04-11-2016, 09:56 PM Thread Starter
In "on" it whine till I cover the outlets with a finger. in "off" its silent. failure coming?
I tested my 2002 petcock valve a few nights ago (it was ok) and then realized I did two stupid things. 1) I used more vacuum than the engine might make with hand pump 2) I left straight seafoam in the tank.
Today I noticed a high pitch whine, picked up tank and... it leak just a little bit. I am thinking the that something is failing in that valve or will fail soon if that makes sense.
If you were me would just put a new tw200 on?
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #2 of 12 (permalink) Old 04-11-2016, 11:29 PM
RoadHopper's Avatar
I'd do that just to compare the two since the tw200 is cheap. Worst that could happen is you end up with a spare petcock.
Is it worth that pricetag/work to answer your question?
RoadHopper is offline
post #3 of 12 (permalink) Old 04-11-2016, 11:41 PM Thread Starter
Well said!
The thing is I don't know if a failing diaphram could prevent successfullfeeding. I try not to buy un-needed parts - but I hear ya.
I do understand I could put it "off" to prevent flooding since that function is not vaccum\diaphram related just like the tws200.
2002 vn750
40/138 jetting
gidaeon is offline
post #4 of 12 (permalink) Old 04-12-2016, 01:07 AM
A whining from the petcock? Its known to clack when the spring gets weak, but not whine. That's odd.
I personally prefer the OEM petcock over the tw200 design. Easy enough to rebuild yours.
jonlandrum likes this.
post #5 of 12 (permalink) Old 04-12-2016, 12:30 PM
I agree with Tanner....a whining petcock sounds like a bad diaphragm or a straight up leak from vacuum port to fuel ports.
Rebuild it and keep the original.
FYI: I now have a modified tank with a Pingel petcock that is gravity fed....I lost the safety feature of the stock petcock to prevent fuel flow if the carb float sticks open......and it makes me nervous since I have gotten into the habit of never turning my fuel petcock off.
I imagine walking into my shed one day and finding a huge puddle of fuel on the ground....not to mention a leaky float could fill up your crankcase with fuel.
post #6 of 12 (permalink) Old 04-12-2016, 12:46 PM
If you used too much vacuum on the petcock, you could have ruptured the diaphragm...that might make it squeal.
So yes, replace or rebuild it.
WilliamTech likes this.
post #7 of 12 (permalink) Old 04-12-2016, 12:56 PM
Yes, but I think this from post #1 is the culprit....
(Petcock) rubber does not perform well soaked in Seafoam......
EDIT: I stand corrected in above knowledgible members....sorry
post #8 of 12 (permalink) Old 04-12-2016, 03:05 PM
I don't recall Seafoam ever doing any damage to rubber.
Carb cleaner will eat up rubber, but I don't think Seafoam would do much harm. If anything, it would condition and swell the seals and rubber a bit and actually make a better seal...no?
post #9 of 12 (permalink) Old 04-12-2016, 04:53 PM
Really , well thankful for setting me straight......I trust your knowledge....I thought it was harmful in the carbs seals...(in time soaking).
TY for the education....
Good info....thanks again
post #10 of 12 (permalink) Old 04-12-2016, 04:57 PM
^ what he said. Never seen a problem with Seafoam and rubber (or synthetic rubber)
I put a rubber O ring, a nylon washer, and some red gasket material in a jar with Seafoam in it. Let it sit a week. Nothing happened.
WilliamTech and thtanner like this.
