Stuck on a fuel leak issue. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 04-01-2016, 09:08 AM Thread Starter
One side the of the fuel line seems to have some sort of back pressure issue. Once one line is fully connected from the petcock to the filter to the carb it will leak fuel from the filter and the petcock fitting. It's almost like there is to much pressure in the line. I have no idea why. I've tried different filters. The line doesn't appear to be clogged or leak as it only leaks at the filter and petcock fitting.
Anyone have any ideas? It didn't do this when I originally got the bike, only when I started reassembling the bike after replacing some parts.
ninjafaces is offline
post #2 of 6 (permalink) Old 04-01-2016, 09:22 AM
calebj's Avatar
Can you take a picture of how you have everything hooked up and where it's leaking?
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
post #3 of 6 (permalink) Old 04-01-2016, 10:18 AM Thread Starter
Yeah sure, I'll take one later on tonight. I'm about to go to bed (I work nights)
post #4 of 6 (permalink) Old 04-01-2016, 11:15 AM
Are there clamps on the hoses? These carbs sometimes tend to not play well with filters installed.
Time for new hoses maybe?
I wouldn't expect to see excess pressure, unless the tank vents are plugged tight and it's sitting in blazing sun.
post #5 of 6 (permalink) Old 04-01-2016, 11:33 AM
Yes fuel is gravity fed, there's no "pressure" there. The fittings on the petcock are just pressed in, and they can get loose and leak.
I'd suggest removing the filters and installing new line (5/16 ID)
post #6 of 6 (permalink) Old 04-02-2016, 01:48 AM Thread Starter
Fixed with new fuel line and fittings.
Now the battery is dead, if it isn't one thing it's another with this bike. :P
