Fuel from keyhole in petrol cap - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 03-14-2016, 06:15 PM Thread Starter
johnoni's Avatar
Still got this problem. Only happens when the tank is pretty full. A small amount of fuel comes up through the keyhole.I have taken the petrol cap off and cleaned and blew out vents etc. But it still does it. Would changing out the petrol cap help or is it a bigger problem I need to address. Thanks
johnoni is offline
post #2 of 9 (permalink) Old 03-14-2016, 08:46 PM
It could be that the tank was not venting right, and a previous owner took the cap apart and removed the diaphragm, so it would vent properly. This was a common problem on CA models. When they worked, you would hear a whistling noise after shutting of the engine. But it didn't take ethanol gas long to melt the rubber parts and plug up the vent. Do you know if you have a CA model or not? they were sold all over the country. In fact, during the later years I don't know if they even made any non CA models. If you have 2 fittings on the back end of the tank, under the front of the seat, pull the hoses off and see if that helps. If it does, you probably have a ton (only a slight exaggeration) of emissions crap that needs to be removed.
2006 Sportster 1200 Low
2004 Honda Rebel 250
1979 Vespa P200E
2002 Vulcan 750 parts bike
1994 Yamaha XT225 parts bike
VN750Rider/Jerry is offline
post #3 of 9 (permalink) Old 03-14-2016, 09:24 PM
2000 VN 750 Senior Member
I would be strange if he had a CA model there in Ireland, although possible.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #4 of 9 (permalink) Old 03-15-2016, 05:59 AM Thread Starter
johnoni's Avatar
Yes. I have 2 hoses coming of the bottom of the tank at front of seat. So my question is. How do I get rid of all the emissions crap you have mentioned. Thanks for your replies as it bothers me that fuel comes out here. Worried in case at some point enough comes out and runs down tank and drips onto a hot engine. Should point out as well this only happens when the bike is in motion. Carry a cloth around to clear up the access. lol.
johnoni is offline
post #5 of 9 (permalink) Old 03-15-2016, 01:20 PM
Search the site for the marbling procedure. That sorts most of it out in one go.
post #6 of 9 (permalink) Old 03-15-2016, 01:28 PM
and they definately made non california models later in the run.. my 2005 is non california emissions
michiganteddybear is offline
post #7 of 9 (permalink) Old 03-15-2016, 01:36 PM
Yes.any bike NOT sold in Nazifornia didn't have the California emission crap.it would not make economic sense for a company to put all that stuff on a model when only one state in the world requires it.they are added on later
post #8 of 9 (permalink) Old 03-15-2016, 01:41 PM
Actually you will find CA bikes can be found outside of the state exist simply due to excess tanks, and other bits. I've seen CA tanks in the EU, Canada, and other nearby states like AZ (first sold there, not transports from CA).
They exist, albeit not super common. You'll find manufacturers will often use what they have, so if they have an extra 1500 CA tanks (or whole bikes, even), they'll ship them out with those provisions.
post #9 of 9 (permalink) Old 03-15-2016, 02:33 PM
But they were produced as a special run FOR California is what I meant by that.
