Want to clean my carbs..need some advice!! - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 8Likes
post #1 of 15 (permalink) Old 03-04-2016, 10:46 PM Thread Starter
woochard's Avatar
Pulled the carbs of my bike and I am going to try and clean them myself..carburetor virgin here any tips anyone can give me would be greatly appreciated..c'mon guys light it up!!
Sent from my SCH-S960L using Tapatalk
woochard is offline
post #2 of 15 (permalink) Old 03-04-2016, 11:30 PM
When removing the bowls put the Phillips screwdriver in the screw and tap with a screwdriver
woochard and jonlandrum like this.
post #3 of 15 (permalink) Old 03-05-2016, 01:15 AM
Would actually do that on all the screws on the carb
post #4 of 15 (permalink) Old 03-05-2016, 09:49 AM
Be careful not to mix parts between the two carbs, at least the needle on the diaphragm assembly is a different size. Have also read of people finding different size jets in the two carbs.
post #5 of 15 (permalink) Old 03-08-2016, 10:39 PM
MisterShai's Avatar
MisterShai is offline
post #6 of 15 (permalink) Old 04-06-2016, 02:34 PM
That was a fantastic video! Nicely done!
McQueenie is offline
post #7 of 15 (permalink) Old 04-29-2016, 02:05 PM
Great video!
Z-Rider is offline
post #8 of 15 (permalink) Old 05-01-2016, 01:38 AM
I'm a rider
One1's Avatar
Someone must have been in those carbs before, like roaches carbs on his rebuild video. They are identical and all my parts were when I put it back together today. I think its a good idea to check when you pull them apart to see if something has been changed. I took pics of mine soaking in cleaner before they were put back in.
Name:	Screen Shot 2016-05-01 at 1.39.19 AM.jpg
1981 KZ750
1988 Vulcan VN750 (red)
2005 Vulcan VN750 (silver)
(2) 1994 Vulcan VN750 (red)
One1 is offline
post #9 of 15 (permalink) Old 05-01-2016, 09:03 AM
They look the same or are the numbers the same?
post #10 of 15 (permalink) Old 05-01-2016, 01:08 PM
I'm a rider
One1's Avatar
Same and same. Externally the hardware mounts differently to accommodate the cables, but internally the cylinders, heads, and carbs are set to be timed, adjusted, and synchronized together. You couldn't synchronize them if they were different. They'd pull differently on the vacuum.
1981 KZ750
One1 is offline
