rejetting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 12 (permalink) Old 01-24-2016, 05:47 PM Thread Starter
rejetting
i am going to earshave and use pod filters also open exhuast up.so as far as rejetting do i need to get a entire jet kit where i will be drilling the slides and everything or can i just get the 142/42 jets and install them any suggestions and help will be greatly appreciated ty
boanz is offline
post #2 of 12 (permalink) Old 01-24-2016, 06:20 PM
Alpha Geek
Hexadecimus's Avatar
40, 140 with a coaster/marbling and 3.5 turns is probably closer. 42 pilots might be okay, but it will suck a lot more gas and you'll need to dial back the screws to find best lean idle. "Best lean idle" first (http://www.redlineweber.com/html/Tec...lean_best_.htm), then mains at WOT and a plug chop to set your top end, then shims if necessary to cure lean surging at cruise speeds and tune the midrange. If 4 shims doesn't do it, go to 42's and zero shims, retune from the beginning. Midrange is still mostly pilots, so a bump up there can help.
I run 38/140 and 3.5-4 turns with pod filters, coastered, and wide open slip-on Screamin' Eagle "mufflers". I put that in quotes because they're empty pipes.
I have no lean problems, starts and runs great, and probably the best mpg of anyone on here.
Excerpt from my patented super duper nifty neato jet cross-section charts:
# area % change
38 0.11 1.00
40 0.13 1.11
42 0.14 1.22
# area % change
132 1.37 1.00
135 1.43 1.05
138 1.50 1.09
140 1.54 1.12
142 1.58 1.16
145 1.65 1.21
148 1.72 1.26
150 1.77 1.29
If anyone is going past about +15%, they either have forged internals and a turbo, they're masking some other huge problem, or they're copying bad advice from all the people who like to massively over-jet.
As you can see, there's a huge % change when you swap pilots. That's why we need to play with the screws to fine tune it. Each size bump begins to drop in larger sizes because it's based on diameter, while fuel flow is based on cross-sectional area. We really need about a +15% option on pilots and #138 mains.
Think about how much extra air you're getting and power you're making. Most intake/exhaust combinations won't get more than 5-10% gain, 8-12% if you're doing lollipops, torque cones, etc. to really tune it right. That's the increase in jet size you should shoot for.
Hexadecimus is offline
post #3 of 12 (permalink) Old 01-24-2016, 06:33 PM
I'm at 1100ft, degoated with screaming eagles, earshave with k&n pods,and 140/40 and two shims.but every bike is different and Hex's guidelines are a great start.now Jason,gonna put up some pics of that new toy ya got?
post #4 of 12 (permalink) Old 01-24-2016, 07:08 PM Thread Starter
tyvm on the info was just going off another on here i saw with those jets.so what jet kit should i go with??i know of factory pro,dynajet and i was looking at the 6sigma kit.what do u suggest?as im new to the motorcycle repair and the performance side of it all.i am a auto mechanic with quite a few years exp.pretty much if it has a motor i can figure it out.ty again
boanz is offline
post #5 of 12 (permalink) Old 01-24-2016, 07:13 PM Thread Starter
oh and what size pods am i looking for i saw u had something on ur bike rc 23xx???
boanz is offline
post #6 of 12 (permalink) Old 01-24-2016, 07:44 PM
K&N 2340
post #7 of 12 (permalink) Old 07-13-2016, 02:29 PM
Where do you get your coasters?
Tank126 is offline
post #8 of 12 (permalink) Old 07-13-2016, 08:03 PM
Coaster
or do what I and other cheap people did and just use 5/8" caps that are .50ea at auto parts store.
OleDirtyDoc likes this.
2002 vn750
AGM battery, Shinko 230 tires oversized front
Ear shaved - k&n pods, drilled clutch basket
40/138 jetting
If I can split a case and make it work - you can too!
Forum pictures:http://s150.photobucket.com/user/Gid...?sort=3&page=1
gidaeon is offline
post #9 of 12 (permalink) Old 07-14-2016, 09:35 AM
Originally Posted by gidaeon View Post
Coaster
Yup 5/8" caps
post #10 of 12 (permalink) Old 07-14-2016, 10:08 AM
Alpha Geek
I tried caps but my bike blew them off within 2 miles so I corked from the inside as well, plus caps, plus RTV between them. I prefer coasters. You can also "marble" the hoses.
