carb troubles - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
  • 1 Post By boanz
post #1 of 3 (permalink) Old 01-21-2016, 08:55 AM Thread Starter
carb troubles
Hi, looking for advice. I have a problem with the carbs. My bike hardly starts and speeds do not exceed 4000. The carburetors were cleaned ultrasonically. We tried carbs from another bike and speed went up to 8000. What can be done to solve this problem except for the purchase of new carbs?
Lilith is offline
post #2 of 3 (permalink) Old 01-24-2016, 12:16 PM
only thing i can suggest is make sure jets and tubes are clear and also make sure diaphrams arent bad that when u push them up they make a good wooshing sound and also chk the cut off diaphram i think thats wat its called its the small round 1 on side of carb cover has 2 screws mine did same thing and the cut off diaphram or valve had junk in it and also chk the floats make sure levels are correct if u need any help ill do my best just ask mine did same thing and after i cleaned them and found the junk in cut off valve they work fine
Lilith likes this.
boanz is offline
post #3 of 3 (permalink) Old 01-25-2016, 03:35 AM Thread Starter
thaks a lot. I'll try it and let you know.
Lilith is offline
