Gas Petcock Problem...... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 2 (permalink) Old 01-19-2016, 08:09 AM Thread Starter
93VN750's Avatar
My petcock needs to be either rebuilt or replaced. Gas flows through it no matter what, even in off.
I had oil/gas leaking out of the weep hole, does this mean the carb float is stuck/bad, or will constantly flowing gas get through no matter what?
I watched the level in the oil sight glass go up as the gas flowed in, it took a few days, but what came out the weep hole definitely was gas and oil.
Rebuild existing petcock, get new OEM petcock, or get the "other" one people have bought as a replacement.
Thanks in advance for the help.
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 2 (permalink) Old 01-19-2016, 10:46 AM
calebj's Avatar
The alternate OEM replacement from the TW200 is only about $16 brand new. To me that's a no brainer compared to rebuilding the original unit. Part number is 23F-24500-20-00. You can even order it (the OEM TW200 unit, not a knock off) from Amazon with Prime shipping for less than $19.
http://www.amazon.com/Yamaha-23F2450.../dp/B004K9I1KI
1986 VN750 27k miles
1999 EN500 32k
1983 GL650i in pieces. Someday it will ride again.
calebj is offline
