building a manifold - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 11 (permalink) Old 07-30-2008, 12:07 AM Thread Starter
building a manifold
we will put a big Mikuni on the 750..........My guru/alley buds and I will mount and fix a single Mikuni on this bike ...I had it down the inventive alley tonight for the first time and it can be done..........
barstar is offline
post #2 of 11 (permalink) Old 07-30-2008, 05:29 AM
750Doug's Avatar
750Doug is offline
post #3 of 11 (permalink) Old 07-30-2008, 11:17 AM
dirtrack650's Avatar
I'm interested. Nylon, aluminum, steel, carbon fiber, what's your choice for materials?
DT
95 VN750 (eBay)31k+
GL1100 front fender
OEM engine guard
OEM high back rest
'V-Twin' HWY pegs
Black 750 Spectre handlebars
SunPro Volt Meter (Amazon)
Maier bug shield (JCW)
Bar Ends anti-vibe (JCW)
Emgo air filters
Tank bag-Eclipse
Tail bag-FroZone Cooler
Back Rest-Igloo 6 pak cooler
WalMart Saddle Bags
Dry Splines Lubed
AGM DieHard-Sears
Gutted Goat
Sporster XL Mufflers
LED's-stop,tail,turn,marker
Pickup coil mod to .45mm
Silverstar headlight
Rotella T6
dirtrack650 is offline
post #4 of 11 (permalink) Old 07-30-2008, 01:03 PM
Chucklehead
dragon159's Avatar
I'm sure you have a number of members' attention right now. If you get it figured out be sure to post plenty of pictures and how-to's. The what-happened's are also helpful even if they don't work. I'll be watching!!
"Squirrel Bike" aka Jersey
Rat bike with a good PR agent
shaved and coastered
2 into 1 exhaust
rear 170 and front 110
custom dash with voltmeter
Spitfire windscreen
Plutonium plugs
More to come
dragon159 is offline
post #5 of 11 (permalink) Old 07-30-2008, 02:15 PM
Well, we've used one other Hogan's Hero's cast in another thread, so how about another.....
Verrrrrry Interesting!!
post #6 of 11 (permalink) Old 07-30-2008, 02:31 PM
Originally Posted by 750Doug View Post
OH Pic Please Please Please Pleeeeeeeeze
85 VN750 basketcase ( yes its a true 750, and no smog controls, its good to be Canadian)
It will have
a rebuilt 96 top end, rebuilt 85 bottom end
degoated, Eared
stripped, lowered, raked, bobbed,
reed valve boxes shaved
ported and polished
balanced
right side dump exhaust
heads and cylinders shaved for compression
looking for smoothbore sidedraft carbs
possibly fat bob tanks
modified vn800 or sportster drag pipes or I'll just make some
Chopperfix
Duck's Garage
Duck is offline
post #7 of 11 (permalink) Old 07-30-2008, 03:48 PM
Glenn M's Avatar
Ya, let's see it and some spec's. Big Mikuni?
Glenn
1985 VN700
Saddle Bags
Small Sport Windshield
R/R moved
Home built coasters
Kaw touring front fender
1990 Fuel tank
Kenda Kruz 110/90-19 & 170/80-15 tires
NGK Iridium plugs
NGK plug caps and 7mm copper core wires.
Deer Whistles
My VN700 pic's
VROC #7740
Glenn M is offline
post #8 of 11 (permalink) Old 07-30-2008, 06:42 PM
Sky Rider's Avatar
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #9 of 11 (permalink) Old 07-30-2008, 06:46 PM
Chucklehead
dragon159's Avatar
I was just sitting here looking at the motor on the floor examining the carb mounts on the cylinders. As much as I like the idea, the angles of the ports would cause one of the runners to almost a 180 bend (not good for intake balance in my book)unless they came down from the top and there isn't enough room under the tank for that. But if you can do it, more power to ya!!
2 into 1 exhaust
Spitfire windscreen
Plutonium plugs
More to come
post #10 of 11 (permalink) Old 07-31-2008, 06:16 AM
750Doug's Avatar
750Doug is offline
