2 Idle issues - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 15 (permalink) Old 11-30-2015, 05:44 PM Thread Starter
2 Idle issues
Hey guys. So I have a 2002 earshaved vn750 with close to 24k miles. It has both the MF battery and the expensive spark plugs. I have two issues I have been fighting with ever since I did the ear shave this past May. the reason I did the ear shave was because I had to take my carbs off to replace a torn slide diaphragm. The problems I have had since are:
1st: When revving up the rpms never go back down to normal idle like they used to. It probably takes it about 4 seconds (the Mississippi kind) for it to get back to normal idle. Is this normal? I feel like it shouldn't be...
2nd: This problem has been getting progressively worse, but once the bike is warmed up enough for the fan to kick in the bike cannot idle at 1100 rpms like it is supposed to. It will try to and then it acts like it is misfiring or something until the rpms drop too low and it dies. I actually have it set at about 1700 rpms so it wont die on me.
Now I found on here that I should check my voltage at my battery and see what that says. The reading go from: 13ish cold. Idle: low 14ish reving it: 14.5 ish . When the fan kicks on it will crawl down from 14 until it is around 13 & when it dips below 13v the bike starts misfiring (I think) till it dies.
I have been trying to solve this issues for months now and had to ride it out to CA from TX like this....any wisdom passed my way will be appreciated
(also I have a video of the 1st issue, but can't post it here for some reason)
2002 Kawasaki Vulcan 750
1979 VW Bus/Westfalia
KFred09 is offline
post #2 of 15 (permalink) Old 11-30-2015, 06:09 PM
Sounds like an intake leak.spray starting fluid around the base of the carbs.if it revs up you have an air leak
post #3 of 15 (permalink) Old 11-30-2015, 06:26 PM
x2 on #1
If you find a boot leaking, try to re-seat the carb, and watch the alignment marks.
On #2 the charging system doesn't seem to be keeping up, which could be the stator, but possibly more likely the R/R.
Look at The Two Wire Mod, sticky post, in the Electrical section and see what you think. It's simple enough to try, and also avoids future problems in the Junction Box.
What is your battery voltage before starting?
post #4 of 15 (permalink) Old 11-30-2015, 07:57 PM Thread Starter
Damn....If it is a carb boot intake leak I must not know what the hell I am doing. I have taken these things off and on several times to make sure there is no leak and I have the same problem everytime. On this starting fluid trick. If I spray the fluid anywhere in that area won't the RPMs pick up anyway because the air intake will suck in the fumes?? Just want to make sure I do it right. Let me go check what the resting voltage is.
KFred09 is offline
post #5 of 15 (permalink) Old 11-30-2015, 08:00 PM Thread Starter
KFred09 is offline
post #6 of 15 (permalink) Old 11-30-2015, 08:23 PM Thread Starter
x2 on #1
I will give that sticky a look see. Anything to help out! I just went and checked. The resting voltage before I start it is about 13.25 volts. then when idle (not so warm the fan is on) the voltage is around 14.45 volts. then when I revved it, it varied, but stayed around 14 and a half volts.
Also it does not like to idle when it is on it's sidestand for some reason. Is that normal?
KFred09 is offline
post #7 of 15 (permalink) Old 11-30-2015, 08:36 PM
Yes, you could get a false reading due to the open filters being so close.
Some flammable spray lube with the long spray tube to pinpoint the spray might work better. WD40 doesn't burn anymore.
Can also use water, or WD40, except you will get a stumble instead of the idle flaring higher.
post #8 of 15 (permalink) Old 11-30-2015, 08:39 PM
Battery sounds good.
The idle on sidestand could be a float level just a tad too low. (gets worse when leaned over)
post #9 of 15 (permalink) Old 11-30-2015, 08:50 PM Thread Starter
Where are all the places it could leak?? The line from the petcock, the other vaccum line on the side I have plugged, and the boots on the intake are all there is, right? Could that breather line that goes to the front throw something off?
KFred09 is offline
post #10 of 15 (permalink) Old 11-30-2015, 08:51 PM Thread Starter
Could that cause the other problems too?
KFred09 is offline
