Need Petcock to Tank Oring... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
  • 1 Post By slimvulcanrider
post #1 of 6 (permalink) Old 11-26-2015, 02:19 PM Thread Starter
93VN750's Avatar
Question Need Petcock to Tank Oring...
Finally got the bike back together, fueled it, and gas was pouring from the petcock. When I look at the oring, it does not appear to be higher than the edge of the petcock so no seal is made.
Can not find part number on any of the bike part web sites. Do you have to buy a petcock to get the oring?
Thanks,
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #2 of 6 (permalink) Old 11-26-2015, 03:00 PM
take the petcock into your local automotive parts house and ask the guy behind the counter to find an o-ring that fits...
niterider likes this.
post #3 of 6 (permalink) Old 11-26-2015, 06:35 PM
Crowley
crowley1027's Avatar
It's an oval o-ring... Don't know if you can stretch a round one out like that without stressing it.
crowley1027 is offline
post #4 of 6 (permalink) Old 11-26-2015, 06:35 PM
Crowley
I might have one lying around. I'll check in a bit, and let you know what I find.
post #5 of 6 (permalink) Old 11-26-2015, 07:32 PM
calebj's Avatar
Worst case, use the TW200 as a source for the o ring since it fits the same and is less than $20.
calebj is offline
post #6 of 6 (permalink) Old 11-26-2015, 10:28 PM
yup i know its oval, and yup been there done that and made it work, don't remember the size... I just pulled an o-ring out of my metric o-ring assortment pack and put it in.
