Carb trouble - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 1Likes
post #1 of 16 (permalink) Old 11-18-2015, 08:25 PM Thread Starter
Joe-'s Avatar
Carb trouble
First, thank to everyone here. I've been lurking for a while and have gotten a lot of great info.
I picked up an '01 VN750 from a buddy of mine. It had sat for at least a year, and didn't start right away. With a new battery and fresh gas, I was able to ride it home. When I was working on it at his place, I had noticed some gas around the bottom of the right-hand cab, but chalked it up to being flooded from so many failed starts.
A day or so later after I got it home I noticed the bottom half of the left-hand carb was wet with gas. I couldn't tell exactly where it was coming from - I noticed that there was no plug over the mixture screw (either side), and that area was pretty wet; but I'm not sure if that's where it was from.
I thought it might be a stuck float, so I drained both carbs, pulled the tank, and shot carb cleaner down both gas lines. Left side, no problem -- I sprayed till I saw a smooth stream of fluid, then closed the drain and let it soak. But the right side was clogged. I could only spray so much before it backed up through the hose. I even tried to give it a little push with my air compressor, but it would not budge.
So, now I'm thinking a clogged jet. Am I on the right track? If so, is there anything I can do other than pulling the carbs and giving them a thorough cleaning?
Thanks,
Joe
Joe- is offline
post #2 of 16 (permalink) Old 11-18-2015, 08:52 PM
A clogged jet wouldn't stop flow into the bowl, but a stuck float/needle valve stuck closed would.
Can try whacking the carb bowl with a plastic screwdriver handle to see if it will shake loose.
post #3 of 16 (permalink) Old 11-18-2015, 09:32 PM
Look up Wolfie's back blow method as well
post #4 of 16 (permalink) Old 11-19-2015, 06:57 AM Thread Starter
Joe-'s Avatar
I'll try both methods -- thanks!
Joe- is offline
post #5 of 16 (permalink) Old 11-19-2015, 08:01 AM
Mine just leaked. The gasket on the bowl just leaked. I carefully put some red gasket stuff on their very thin and no more leak. Have to be very careful though that you don't get any in the bowl.
post #6 of 16 (permalink) Old 11-19-2015, 10:21 AM
The one that didn't back up through the gas line is the one you have the problem with, it sounds like the floats stuck or there's something keeping the needle valve from closing. Which is making it overfill with fuel and leak.
The blowback method and tapping with a screwdriver handle are both good starts....
post #7 of 16 (permalink) Old 11-19-2015, 11:01 AM
X2 on this.
post #8 of 16 (permalink) Old 11-19-2015, 07:36 PM Thread Starter
Joe-'s Avatar
Do you mean that with the drain open, it should back up through the fuel line? Sorry if it's a noob question, but I thought with the drain open, the bowl would empty and the value would stay open.
Joe- is offline
post #9 of 16 (permalink) Old 11-19-2015, 09:08 PM
Good point.with the drain open it shouldn't back up the fuel line.the needle cave is stuck so no fuel will come into the carb.what did the fuel that came out look like when sustained it?
post #10 of 16 (permalink) Old 11-20-2015, 09:10 AM
Yes, sorry, missed the part about the drains being open while you did this.... But then that would mean a stuck shut valve, which doesn't explain a fuel leak.
The jets would have nothing to do with this, clogged jets just make the bike run bad, not leak fuel. You didn't say the bike didn't run well, just that it was leaking fuel....
So, not sure how the gas line would be blocked up with the bike running OK...
Are you sure it was a fuel line and not a vacuum line you were spraying?
