Reinstalling the ears? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 10-12-2015, 12:04 PM Thread Starter
DR.BADNEWS's Avatar
I have a 2006 Kawasaki Vulcan where the previous owner replaced the exhaust, rejetted(not sure about size), and performed the ear shave mod.
While I'm sure it picks up speed like a champ, but it's impractical for me because of the excessive back firing when decelerating and the engine crankcase breathers keep falling off, all while I'm sure water is getting in the crankcase because I have to ride in all weather all year round.
I bought a replacement surge box and k&N filters fitted for the "ears" but I can't figure out how to get this thing in the frame. I'm at a total loss here how to fit this in and it looks like people cut the surge box to pull it out.
DR.BADNEWS is offline
post #2 of 4 (permalink) Old 10-12-2015, 12:21 PM
The backing on deceleration is incorrect jetting or incorrect A/F screw settings. You do not need to put on the restrictive intake (ears) to prevent that. I'd get a better crankcase breather setup, and potentially get different filters as my K&Ns do not fall off my carbs.
post #3 of 4 (permalink) Old 10-12-2015, 12:49 PM
I had to pull the wiring harness out of the frame, from the battery forward, to get the airbox out in one piece. Once the harness is out of the way, the box will slide in/out from the rear.
The backfires are most likely from a lean idle mix. The reed valve system is said to contribute to backfiring on decel. Is it coastered or still has the reeds? Adjusting the air screws on the carbs should also help.
Not sure how your crankcase filter is set up, but the hose should be clamped. Mine is mounted high where the right ear was, the hose from it runs into the stock hose at the engine, and is clamped there. Any low mounted filter on the stock 90 elbow hose will take more water from the front wheel.
post #4 of 4 (permalink) Old 10-12-2015, 12:54 PM
These carbs also have a coast enrichment valve. If not working, could cause popping on decel.
Air leak at the carb can cause backfire on decel. Mine goes off like a cannon on long decel if I unplug the right side vacuum port (gets capped when you install coasters).
