Choke Not Revving - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 19 (permalink) Old 10-11-2015, 01:29 AM Thread Starter
Ryeloc's Avatar
Choke Not Revving
So my choke isn't revving the engine. It is working the plunger up and down, at full choke the bike dies, It's likely getting flooded, but doesn't have the higher rev's to keep it running. What would be causing the motor to not rev up when choke is applied? Where should I start. I follow the cable and everything seems to move as it should all the way to the plunger.
Ryeloc is offline
post #2 of 19 (permalink) Old 10-11-2015, 07:56 AM
internally to each carb the plunger allows more fuel as well as more air into the system.. soooo, if its flooding, its not getting enough air. pull the carbs and clean them is the way to fix (seafoam wont really work here).
just a note however, if its 'off choke' and I put the choke on, it will stall as well, unless I rev the engine just prior to applying the choke, then the choke will work right. If the engine is off and I apply, then start, it works as designed.
I dont really use the choke much at all, just when first starting, on a stone cold (overnite sit) start. then its fully off within 1-2 minutes.
michiganteddybear is offline
post #3 of 19 (permalink) Old 10-11-2015, 09:31 AM Thread Starter
Ryeloc's Avatar
When using the choke, what causes the engine to rev up? Seems there must be something linked to the throttle. As introducing more fuel, and air with the plunger but nothing changes the rev limit? There MUST be something that controls the rev limit when using the choke.
Ryeloc is offline
post #4 of 19 (permalink) Old 10-11-2015, 09:38 AM
calebj's Avatar
Nothing is touching the 'Rev limit'. By introducing more fuel and air the engine will naturally spin faster just as if you'd rolled on the throttle (though with a slightly richer mixture in this case).
calebj is offline
post #5 of 19 (permalink) Old 10-11-2015, 09:50 AM Thread Starter
Ryeloc's Avatar
So that's kind of strange to me. So you think the carbs need to be cleaned. The bike runs fine all the time, this is the only thing that doesn't work. I never have a problem with it starting, I'm just foreseeing a problem in colder months with a choke not working.
When I add choke to the running engine, it just dies. Even if it is warmed up, if I add it to a cold engine it dies as well. Do you think it's being flooded with gas and not getting enough air?
Ryeloc is offline
post #6 of 19 (permalink) Old 10-11-2015, 10:35 AM
It does sound like a clogged air circuit.
Not sure I can stall mine when hot by using the choke, but I know I can pull the idle to 3500 and higher, anytime, just by pulling the choke.
This 'choke' is actually an enricher, since there is no choke plate or butterfly.
post #7 of 19 (permalink) Old 10-11-2015, 12:03 PM Thread Starter
Ryeloc's Avatar
I talked with my Dad about this as well, he seems to think it's already choked, and by choking the engine or cutting the air down, it's just killing it. He said that the rear carburetor is running rich, that's why the back head is wet. Awhile back we removed the plugs and found the rear head spark plugs to be wet. The front seemed to be running right. He said if the back is running rich, and u choke it. Decreasing the air, since the mixture is already rich it's basically over choking it and killing it. He said I need to count the turns on the front carb when putting it at 0, then back it off the same amount. Since the front carb and head seems to burn right. Then do the back carburetor, he said it's likely to be more turns because it's burning rich. Then back it off the same turns as the front carburetor.
Does anyone of this sounds accurate, love my dad but sometimes he can be in left field! lol
Ryeloc is offline
post #8 of 19 (permalink) Old 10-11-2015, 12:15 PM
Your dad could be correct, if this was a conventional choke. But that's what I was explaining about it being an enricher, and not an actual choke. It enriches by adding fuel, not decreasing air, since it has no choke plate as normally found on carbs.
Not sure where you are "counting turns", choke cables, air mixtures, throttle cables? If your air mixture screws have been uncapped, it wouldn't hurt to check them.
If the rear cyl. is that rich, it may be an internal issue on that carb.
post #9 of 19 (permalink) Old 10-11-2015, 12:19 PM
Sounds like the float needle on the rear carb could be dirty?
post #10 of 19 (permalink) Old 10-11-2015, 12:24 PM
Is the rear cyl. actually firing? Does it get hot like the front cyl. does?
