Fuel Gauge Just Went Stupid - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 09-19-2015, 04:42 PM Thread Starter
TechMech's Avatar
I just put on a new R/R and thought I had solved my electrical problem. I took the bike for a ride and noticed the fuel gauge was at the half-way mark. In a few miles it dropped to a quarter. Then went back to a half then went to the mark just above the red E line. This was all in the space of about 15 miles. I stopped to fill up and only needed 1.66 gallons (and I fill it to the top). Never had a problem with the gauge before. What should I try?
TechMech is offline
post #2 of 5 (permalink) Old 09-19-2015, 04:56 PM
Check the electrical connection that comes from the tank's fuel level sender. Make sure it's nice and clean with electrics cleaner, and pack it with dielectric grease.
post #3 of 5 (permalink) Old 09-19-2015, 07:30 PM
I agree with tanner about using dielectric grease to seal the connector from moisture and prevent oxidation.
Just remember that dielectric grease is an insulator, and the connector needs to fit tightly so the grease is forced out from between the metal contact surfaces.
post #4 of 5 (permalink) Old 09-19-2015, 07:32 PM
2000 VN 750 Senior Member
Make sure you are not reading the gauge while on a hill. I can bounce my front end while holding the front brake and watch the gauge bounce. Just a thought for you to consider.
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #5 of 5 (permalink) Old 09-28-2015, 04:53 PM Thread Starter
TechMech's Avatar
That seems to have been the problem. I sprayed contact cleaner into both parts of the connector and now the gauge works fine. A simple fix. Thanks for the suggestion.
TechMech is offline
