seafoam? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 2Likes
post #1 of 20 (permalink) Old 09-16-2015, 02:10 PM Thread Starter
mayor of Narnia
minikrew's Avatar
Question seafoam?
I have a ? about seafoam how much per gal. in the tank and how much in the oil . how long do i leave it in the crankcase? thanks for the help minikrew
minikrew is offline
post #2 of 20 (permalink) Old 09-16-2015, 02:14 PM
There's no real reason to run Seafoam in the crankcase, imo. I don't know of any oil passages that become clogged, etc, so I can't see why you'd want to.
As far as in fuel, follow the directions on the back of the can.
post #3 of 20 (permalink) Old 09-16-2015, 02:30 PM Thread Starter
mayor of Narnia
minikrew's Avatar
the oil level window is very dark ( cant see the oil level ) i read on here to clean it with a littil seafoam
new supetrapp mufflers
led turn lights
talked to wolfie got highway pegs
to late to bring back wolfie now ride on brother
degoated
new rear drive & splines lubed h-pipe installed riding on the darkside
minikrew is offline
post #4 of 20 (permalink) Old 09-16-2015, 02:39 PM
Seafoam thins oil and reduces lubrication. You can try but I wouldn't run it more than a few minutes at most (as most suggest anyways).
Often times when the window is dark people have it overfilled (so cant see a bubble). If the window is that dark with the oil drained, then it would worry me what the rest of the engine looks like inside.
post #5 of 20 (permalink) Old 09-16-2015, 03:13 PM Thread Starter
mayor of Narnia
minikrew's Avatar
thankx that is why i am asking the bike runs gr8 and i want too keep it that way
led turn lights
degoated
minikrew is offline
post #6 of 20 (permalink) Old 09-16-2015, 04:46 PM
If you do put it in your case, change the oil after running it 50 mules or so. You don't want any residual left in there.
All the direction are I belive on their site. I've looked it up somewhere.
post #7 of 20 (permalink) Old 09-16-2015, 06:03 PM
I used two shots per tankful (on a full tank) with a standard shot glass.
post #8 of 20 (permalink) Old 09-16-2015, 06:43 PM
Headbanger/Popes of Hell
ruger's Avatar
ha ha he said "mules".
ruger is offline
post #9 of 20 (permalink) Old 09-16-2015, 07:54 PM
Should be about 1oz. per gal in gas, oil has another measurement per qt. The print on the can is so small, I wrote the doses on the side with a marker.
There are a few places seafoam can help in the oil. Valve stems, starter clutch, and clutch basket.
I ran it in the oil 300 miles before an oil change, cleared up a sticky valve and almost eliminated coffee grinder syndrome. I'll probably run it again just before the next oil change.
You really don't add enough to dilute the oil.
post #10 of 20 (permalink) Old 09-16-2015, 08:15 PM
Bingo.
