From "ON" to "RES" - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-09-2008, 02:00 PM Thread Starter
From "ON" to "RES"
I have a 2006 VN750 and have an issue when switching from "ON" to "RES." When I first got the bike, the engine would die when I started running out of fuel and switched to reserve while riding. I would have to pull over and wait a few minutes before the bike would start again on reserve. I took the bike back to the dealer and they cut a little excess fuel line which seems to fix the problem.
Two years have passed and I haven't had much of a problem...until today.
The bike started to chug along so I reached down and flipped the switch, but it seems like it's taking too long for the fuel to flow or something. I pulled over, waited a minute and started the bike and went on my way.
Anybody have any idea as to what would be causing this? Is this heat related because this has only been an issue in the warmer weather?
Thanks
J
Jaffaj is offline
post #2 of 9 (permalink) Old 07-09-2008, 02:13 PM
93VN750's Avatar
It's possible that the pickup tube for the reserve position is partially clogged. I always run fuel through the reserve on every tank to keep it freeflowing.
Try a tank of fuel with Seafoam in it and run it through on reserve only. Just watch your mileage so you don't run out of gas.
Jon
vn750.com Member # 828
Rick's Stator and R/R
MF AGM Battery
Degoated
Shaved & Jetted
Iridium's
MAC Tapered Staggered Pipes
Battery/Temp/Clock Gauge
Stainless Steel Brake Lines
Dunlop D-404's
93VN750 is offline
post #3 of 9 (permalink) Old 07-09-2008, 02:13 PM
Louder IS better!
BlackOctober750's Avatar
My bike did this goin down the interstate...not a fun place for the bike to die. I just figured I sucked the carb dry. But now you have me curious.
16,000 Miles
HAVE:
V-Force Windshield
V&H Cruzer Pipes
Luggage Rack
Lo-Jack
Intact Toolbox
Avon Venom Tires
Tour Master Cruiser II Slant Bags
K&N Air Filter
Custom Grill
NEED(want)
Engine Guard
16" Ape Hangers
Forward Controls
New Grips
New Mirrors
Driver Backrest
Passenger Backrest
BlackOctober750 is offline
post #4 of 9 (permalink) Old 07-09-2008, 03:41 PM
99vulcan750's Avatar
I always run with reserve on as well and try to fill up with 2.25 gallons every 100 miles or so.
'99 VN750 with 8900 miles and growing (3,111 when I bought it 03-22-08)
Ear shave with Unipods
Drilled mufflers and degoat
TOC springs
N/C Street shield EX windshield
Jumbo Saddleman Highway Studded saddlebags
Willie and Max Saddlebag mounting kit
License plate turn signals
Home made sissy bar
Luggage Rack from Scoop
http://youtube.com/user/99vulcan750
99vulcan750 is offline
post #5 of 9 (permalink) Old 07-10-2008, 11:59 AM Thread Starter
Thanks to all for your suggestions!
Jaffaj is offline
post #6 of 9 (permalink) Old 07-10-2008, 12:28 PM
fergy's Avatar
It does take a few seconds for the bowl to refill and if your bike dies or sputters before you switch to res, your bowl is empty so you would have to coast a ways before the engine would catch. Problem is, when the bike sputters, you need your left hand to turn it to reserve, and the engine is braking the bike, so it's slowing down quickly. If they'd put the petcock on the right, you could pull the clutch and coast better while turning it to reserve, and then let off the clutch a few times to see if it would re-start, as you are coasting. Since we can't do that, it's just better to know about how many miles you need to switch to reserve before you run the carbs dry.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
post #7 of 9 (permalink) Old 07-10-2008, 09:17 PM
Gemguy's Avatar
I had this happen a couple of times. I figured out that I wasn't paying attention to the engine. If I had switched the petcock at the first hesitation it would make a smooth transition but I waited till it was barely running and that's when I had the problem. It takes a few minutes until gravity restores an even fuel flow and all is well again.
Gemguy is offline
post #8 of 9 (permalink) Old 07-10-2008, 10:12 PM
yup.. me too... slow learner... happened to me 3 times, lol..
TOC springs
Home made sissy bar
post #9 of 9 (permalink) Old 07-10-2008, 10:31 PM
Also...read this thread:
http://tinyurl.com/6rf47n
