Tuning (Jetting) Keihin CV Carbs for the VN750 - Page 6 - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
 12Likes
post #51 of 54 (permalink) Old 10-23-2018, 04:00 PM
lugnut1009's Avatar
Originally Posted by Steven Woodman-Dix View Post
I’ve got stock air filters (that I want to keep) and Jardine drag pipes. It bogs down in 4/5/6 gears at about 4800 to 5200 rpm.
Any body able to give me a pointer?
I would suggest to try a couple shims under the needles first.
-2016 Indian Springfield
Chieftain bars
Roadmaster heated seat
-1999 Kawasaki Vulcan 750
Ear shaved
Mufflers removed / 38/140 + 2 shims
Relay coil mod
Pick-up coil mod
Emissions removed
Lowered rear
Rear blinkers located in tail light housing
Petcock gutted
- Wife's: 2018 Can-am Spyder F3 Limited Pearl White
lugnut1009 is offline
post #52 of 54 (permalink) Old 10-23-2018, 07:32 PM
Iíve got stock air filters (that I want to keep) and Jardine drag pipes. It bogs down in 4/5/6 gears at about 4800 to 5200 rpm.
Are the carbs clean and the carb vent hose in the correct spot? Slide diaphragms good?
post #53 of 54 (permalink) Old 10-24-2018, 10:37 PM
6th gear???????? Do you have a 700/750?
roadpouring likes this.
OleDirtyDoc is online now
post #54 of 54 (permalink) Old 10-25-2018, 04:56 AM
kryptonianjorel's Avatar
I've been looking for that 6th gear for a long time, and I see someone has finally found it!
kryptonianjorel is offline
