Need help, new rider bike stalled - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 3 (permalink) Old 08-12-2015, 01:04 PM Thread Starter
Was riding today and bike seemed fine, then all the sudden was stuttering like running out of gas. Had half tank and only 66 miles on this tank. Then it bogged down real bad like it wasn't getting gas before it stalled. messed with the petcock a few times and got it to start once, but soon as in gear stalled again and hasn't turned over since. We removed the petcock and drained the gas looking for stopage in lines which have found none. I am at a loss and I am still learning about bikes. Can anyone give me insight as to what to try next? Friend suggested stuck floater? Any help would be amazing! Thanks in advance!!!
mom2sandm is offline
post #2 of 3 (permalink) Old 08-12-2015, 01:10 PM
Look up poogs(Phantom Out Of Gas Symptoms)
post #3 of 3 (permalink) Old 08-12-2015, 01:57 PM
FastHamFreddy
FastHamFreddy's Avatar
Something similar was happening to mine. It would stall out after riding for some time, then if I let it sit, it would start back up eventually. Look up phantom out of gas syndrome, also if you haven't cleaned the carbs, try running some seafoam through it if you can get it running again. Run a heavy mix (I did half a can with a full new tank of gas). Cleaned mine right up and have not had the issue since.
1987 Vulcan 750
What Has Been Done:
New Battery
Stator Mod
Spline Lube
Starter Relay - replaced
Ignition Coils - replaced
ACCT's to MCCT's
Seat Mod
Re-position Rear Blinkers
New Fork Seals
Lowered Shocks
Ear Shave
Coaster Mod
Still to come:
Remove air box
Side Mount License Plate
Re-Position Horns
New Mirrors
New Exhaust
FastHamFreddy is offline
