How install a throttle cable fitting - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 7 (permalink) Old 07-07-2008, 05:50 AM Thread Starter
Vulcan Bobber
aminjuez's Avatar
Question How install a throttle cable fitting
Somebody installed before a throttle cable fitting in a broken cable end?
I found a kit for repairing a throttle cable fitting in cycledepot.net motion pro kit, but I don't know if I get use welding or what???
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #2 of 7 (permalink) Old 07-07-2008, 08:50 AM
Do you have a part number for what you need to install?
I'm guessing what is broke is an end on the sleeve around the cable?
post #3 of 7 (permalink) Old 07-07-2008, 10:53 AM
Sky Rider's Avatar
I think he's refering to the lead bead on the end of the cable.
The only problem with simply casting a new bead is that the cable would be shortened by the amount that broke off before the bead. Casting new lead is easy but with the shortened cable, he runs the risk of not being able to lower his idle or of going WOT if it's the return cable that broke. If he is replacing the entire cable length and casting beads at both ends, that would work.
Amin, I don't think you would need a welder per se, just a torch to melt the lead to cast into the new bead(s) on the cable end(s).
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #4 of 7 (permalink) Old 07-07-2008, 12:22 PM
If that is the case, I would get a new cable.
I've tried repairing the end bead part and they never seem to hold as good as the original.
post #5 of 7 (permalink) Old 07-07-2008, 03:59 PM
Sky Rider's Avatar
I agree, and the OEM cable will fit with no problems and probably last much longer.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #6 of 7 (permalink) Old 07-08-2008, 03:41 AM Thread Starter
Vulcan Bobber
aminjuez's Avatar
I don't wanna take risk, I found the whole throttle cable for $17.99 in cycledepot.net
1989 Vulcan 750
Bobber style.
33000 miles,
aminjuez is offline
post #7 of 7 (permalink) Old 07-08-2008, 09:34 PM
Sky Rider's Avatar
Good choice.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
