RPM's fluctuating - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 5 (permalink) Old 08-11-2015, 08:49 AM Thread Starter
RPM's fluctuating
My rpm's at idle keep fluctuating. My pastor rode the bike Sunday afternoon and had no problems with it. Then I got on the bike and started it and it was fine until I went to take off and I had the kickstand down and it shut of the bike.
Then I cranked it back up and the rpm's wouldn't go believe 3 or 4k. When I got home I adjusted the idle screw to bring it back down to a little above 1k.
Today I cranked the bike and it wouldn't idle. I had to adjust the idle screw back up for it to idle but when I got to work it was back to idling around 2.5k to 3k.
What is going on to cause this? I am not familiar with this problem.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 5 (permalink) Old 08-11-2015, 08:53 AM
Choke sticking? So by the time you ride a bit and it warms up, the choke lets loose, it gets more air and you have the idle set high. I don't think I ever recall not having to mess with my idle screw as the day wore on.
post #3 of 5 (permalink) Old 08-11-2015, 09:49 AM
JM2001's Avatar
I would check that the throttle cables are working without binding, especially the decelerator cable. If you turn the throttle grip counterclockwise you should have only about an 1/8 th inch freeplay. If you turn the grip to full power and release it ,it should snap back fast.
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #4 of 5 (permalink) Old 08-11-2015, 12:48 PM Thread Starter
the throttle cables was the first thing I checked. Whatever it was it fixed itself while sitting still then I had to adjust it back to where it when I first had the problem.
Don't think it is the choke. But will check.
Richard
post #5 of 5 (permalink) Old 08-11-2015, 02:49 PM
heaney750's Avatar
check the kickstand switch mine gets stuck and causes the same problems tap it with a screwdriver and the problem goes away
heaney750 is offline
