Post Stator Replacement Fuel Problem - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-06-2008, 10:23 PM Thread Starter
Hi all.
I just finished the task of replacing my stator only to have a fuel problem. I'm happy to say that she starts like a champ, but runs very rough and dies when the petcock is in the vertical/run position.
Just for fun, I moved the petcock to the "off" position and the engine runs fine - for a while. I can duplicate the rough run and stall each time I move the petcock to vertical.
Any ideas?
I have a "94 with 35k miles.
Mearaman
mearaman is offline
post #2 of 4 (permalink) Old 07-07-2008, 11:20 AM
Sky Rider's Avatar
Did you try reserve? How does it run there?
Sounds like you may have crud in the petcock valve. You'll probably have to remove the petcock and clean it out.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 4 (permalink) Old 08-17-2008, 12:30 AM Thread Starter
The problem turned out to be a small vacuum leak to the valve. enough vacuum that the fuel was not fully shut off, but bad enough to make her run like crap. replaced the vacuum line and it runs like a champ! There was no residue in the gas tank fuel strainers.
mearaman is offline
post #4 of 4 (permalink) Old 08-17-2008, 06:34 PM
Sky Rider's Avatar
Simple fixes are always a blessing!!!
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
