Hose from air box (Duct) ? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 08-09-2015, 06:12 AM Thread Starter
I have a VN 750 A2 1986. In the front of the duct there is a thick and a thin spigot. Does anyone know where the thin hose are to be connected in the other end ? This hose is 18 inches long and the inside diameter 0.24 inch. There is an S-shaped bend in one end. Spare part number is 92059C.
Hope my english is understandable.
Preben59 is offline
post #2 of 13 (permalink) Old 08-09-2015, 08:02 AM
If your Vulcan has the charcoal emssions tank, the hose probably goes to that. If it does not have the tank, the hose is routed along the inside of the right frame and then lays along side the oil filter in the front of the engine.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #3 of 13 (permalink) Old 08-09-2015, 12:20 PM Thread Starter
Hi and thanks to Vulcan1999
I do have a charcoal emissions tank (guess it's the same as the canister behind the engine?) And the hose I have buy (partno. 92059C) can not reach from the duct to the canister.
Any other proposals ?
Preben59 is offline
post #4 of 13 (permalink) Old 08-09-2015, 02:59 PM
Here is another possibility. The hose could be going to vents on top of the carbs.
post #5 of 13 (permalink) Old 08-10-2015, 02:51 AM Thread Starter
Very interesting. Same partnumber. I will take a look, but may take some days :-)
Thanks a lot. I come back
Preben59 is offline
post #6 of 13 (permalink) Old 08-10-2015, 02:59 AM
y do you have to buy a special hose.. its jsut a vacuum hose sold at any aprts store by the inch
post #7 of 13 (permalink) Old 08-10-2015, 11:36 AM
This sounds like the condensation drain line from the air box. Though I don't think mine has an S-bend.
This line runs down the right side frame tube with metal clips holding it and just hangs with the end open, to drain condensation out of the air box.
post #8 of 13 (permalink) Old 08-10-2015, 12:11 PM
there is a condensation line in the air box? where why haven't we heard of this before?
post #9 of 13 (permalink) Old 08-10-2015, 12:43 PM
It's there, in the same area as the crankcase vent, but on the right side of the bike. (left side when looking from the front) Would be all the way to the front of the airbox, coming out of the lowest point. About a 1/4" hose.
There's been a few posts mentioning it in the past.
post #10 of 13 (permalink) Old 08-11-2015, 12:33 AM
yea.. its not a condensation hose though... the hole doesn't go all the way inside the aire filter housing... its the carb vent hose, which allows the slides to function
