Bad fuel... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 07-06-2008, 12:00 AM Thread Starter
Ba dum dum, ching...
Ron_G's Avatar
Bad fuel...
A couple of days ago I was riding my bike up the driveway when it stalled. When I tried to start it I think I flooded it so I let it sit overnight. Today I got it started but it's running really rough and could only start it by taking the choke off and hitting the starter while holding the throttle wide open. It won't idle sounds really bad. I think it might be a load of bad fuel cause it was running fine and just out of nowhere it started acting up.
While I can do minor things on the bike playing with the carbs scares me silly. Any help is appreciated.
Thanks,
Ron
Yes, it's my mid-life crisis.
Sweet Jane...
http://images5a.snapfish.com/232323232%7Ffp63386%3Enu%3D457%3A%3E6%3C3%3E258%3E  WSNRCG%3D3345343785349nu0mrj
Ron_G is offline
post #2 of 10 (permalink) Old 07-06-2008, 01:53 AM
Now what
Ironman's Avatar
It's probably gas related, but a loose electrical connection can cause the bike to stumble and stall too. Check the battery connections and ground connections because they're easy to check. Make sure they're all tight.
'04 750A- and loving it!
VROC 13864
Using a Purlator One PL14610
Ironman is offline
post #3 of 10 (permalink) Old 07-06-2008, 02:17 AM
liljd's Avatar
Put a half a can of seafoam in the fuel and see if it helps. If it bad gas then it should be fine afterwards. Pm also sent.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #4 of 10 (permalink) Old 07-06-2008, 02:44 AM
ChrisC's Avatar
You could also try to drain the carbs and see what comes out. Ditto on the Seafoam.
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #5 of 10 (permalink) Old 07-06-2008, 04:55 PM Thread Starter
Ron_G's Avatar
OK I put about 1 & 1/2 oz in the tank (I only have about a gal of fuel in the tank). How quickly can I expect to see an improvement?
thanks guys,
R
Sweet Jane...
Ron_G is offline
post #6 of 10 (permalink) Old 07-06-2008, 07:49 PM
Now what
Ironman's Avatar
thanks guys,
R
Seafoam is a solvent and can take a day or so to dissolve whatever is in there. I'd run it a little to work the seafoam all the way into the carbs and let it sit overnight. When you start it up, it could be worse until it gets better. Unfortunately, when Seafoam loosens up the crud, large chunks can shake loose and get stuck in the needle valve. But we can worry about that if it happens.
VROC 13864
Ironman is offline
post #7 of 10 (permalink) Old 07-06-2008, 08:49 PM Thread Starter
Ron_G's Avatar
OK I added about another 4 OZ of Sea Foam and ran the engine for a bit. It's running worse and blowing blue smoke. Is that typical for this stuff or did I blow something?
R
Sweet Jane...
Ron_G is offline
post #8 of 10 (permalink) Old 07-06-2008, 10:59 PM
Now what
Ironman's Avatar
R
Sounds like the Seafoam is doing it's thing. Dissolving stuff. That stuff is getting burned up. Don't worry about it. Let it sit overnight (or longer) and see what happens tomorrow.
VROC 13864
Ironman is offline
post #9 of 10 (permalink) Old 07-07-2008, 08:29 PM Thread Starter
Ron_G's Avatar
OK so I get home from work tonight and pull the bike out of the garage and fire it up. It starts on full choke but where it usually goes quickly above 3K rpms and I have to back the choke down, tonight I won't go above 1500 rpms and when I take the choke off it dies. When I give it gas it sputters and if I don't baby the throttle it chokes out.
Man now I'm really lost...
Ideas?
Thx,
R
Sweet Jane...
Ron_G is offline
post #10 of 10 (permalink) Old 07-08-2008, 12:44 AM
fergy's Avatar
patience. Let the seafoam work for a few more days. Sometimes, it takes a while.
Fergy
2002 VN1500 Classic
Rusty Tank Cleaning!
SEAFOAM JUNKIE!
fergy is offline
