shorter screwdriver - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-31-2015, 02:06 PM Thread Starter
shorter screwdriver
ok, I need a flathead screwdriver that is short enough to adjust the front cylinder carb. Nothing I have will fit. Any suggestions and where to get it?
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 9 (permalink) Old 07-31-2015, 02:53 PM
Calif Rider
weh44att's Avatar
buy a small set of jewelers screw drivers. They come in a small plastic case.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 9 (permalink) Old 07-31-2015, 03:58 PM
I got mine at the dollar store. You can also grind an old one to fit.
post #4 of 9 (permalink) Old 07-31-2015, 04:04 PM
Is this for the mixing screws?
post #5 of 9 (permalink) Old 07-31-2015, 06:46 PM
Seems to me I used an extra long one...what screw are you trying to adjust?
post #6 of 9 (permalink) Old 08-01-2015, 12:28 AM
same here...
post #7 of 9 (permalink) Old 08-01-2015, 01:08 AM Thread Starter
air/gas mixture
Richard
post #8 of 9 (permalink) Old 08-01-2015, 01:52 AM
yup used a really long skinny air/fule mixture screw driver.. exactly what the tool catolouge said it was for.. they also make flexible shaft screwdrivers that I hae used with a little less luck, but they still work.
post #9 of 9 (permalink) Old 08-01-2015, 10:37 AM
Are you sure you're trying to turn the right screw?
