Suggestions where to start? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-02-2008, 06:53 PM Thread Starter
Question Suggestions where to start?
I notice when running at an even throttle and then gun it full throttle, I get a hesitation or slow response before it starts smoothing out again. Like it's not getting enough fuel or air or something. Once it climbs a few RPM's it seems normal again. Anyone else have this happen. If I don't go full throttle it runs just fine, even if I give it gradual throttle it seems fine. I use Seafoam regularly.
My buddy has a Virago 750 and that hesitation is just enough for him to get the jump on me. He had a similar problem due to dirt in his tank and the floats sticking. My tank is clean as can be. Maybe floats?
post #2 of 4 (permalink) Old 07-02-2008, 11:07 PM
Love My Baby
rubyrick's Avatar
Could the vent in the gas cap be obstructed?
rubyrick is offline
post #3 of 4 (permalink) Old 07-02-2008, 11:59 PM
I had the same problem befire changing to iridium plugs.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #4 of 4 (permalink) Old 07-03-2008, 09:38 AM
I was having similar problems on my cage....Found the problem to be the gasket between the carb and intake manifold causing a vacuum leak. so i would look for leaks, and also it could be that your carbs aren't synchronized correctly.
