it's running but.. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-25-2015, 12:44 AM Thread Starter
it's running but..
Well the bike is running pretty good but when I sit idle it smells like I am close to flooding out the bike. Any suggestions?
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 6 (permalink) Old 07-25-2015, 08:04 AM
Look at the spark plugs after it has warmed up and idled for a few minutes and see if they are wet. You could be to rich on the idle/pilot screws.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #3 of 6 (permalink) Old 07-25-2015, 09:06 PM Thread Starter
would that cause hard cranking after running for a while?
Richard
post #4 of 6 (permalink) Old 07-25-2015, 09:33 PM
Crowley
crowley1027's Avatar
Maybe. It might foul the plugs and make it hard to give a spark
crowley1027 is offline
post #5 of 6 (permalink) Old 07-26-2015, 01:14 AM
What rpm do you set the idle? 1000 or just a bit over is a good idle.
post #6 of 6 (permalink) Old 07-26-2015, 08:00 AM Thread Starter
between 1k and 1.5k
Richard
