Fuel to Air Ratio - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 07-20-2015, 08:00 PM Thread Starter
Fuel to Air Ratio
How far can I back out the 2 carb ratio screws? I did the rejet a while back according to the ear shave sticky. 142/42
Now that i've finally got my bike running consistently i need to tune it.
It smells like it's running very rich. I currently have it at front cyl 3 turns. rear 3 1/2 turns.
I don't get popping on decel. I originally had it at front 2 1/2, rear 3 but it smelled so rich i figured i needed more air.
I get a little hesitation (very little) going from a stop.
Occasionally when coming to a light and in neutral it will stay at ~2k-3k rpms a bit before dropping to 1.5k other times it will drop immediately to 1.5k This was more prominent at the previous fuel/air ratio.
Am i properly negating a fuel rich situation or is there a better way? I don't want to back out these screws too far.
OH...almost forgot. Stock exhaust.
Mike
2006 Vulcan 750
Ear Shaved
Re-jetted
ACCT --> MCCT Conversion
TW200 Petcock
www.michaelcmichaeldo.com
mcharles13 is offline
post #2 of 6 (permalink) Old 07-20-2015, 08:01 PM
If your RPMs are slow to drop, check the carb boots. They may not be seated all the way.
I run 3 1/2 turns for front, 3 for rear with V&H Cruzers. You may not need to back yours out as far with stock pipes. Some also may argue a re-jet was not needed without changing your pipes. That one is a bit up in the air, but you may indeed have too large of jets for your exhaust.
post #3 of 6 (permalink) Old 07-20-2015, 08:41 PM
Crowley
crowley1027's Avatar
Turning the adjustment screw out introduces more fuel. Clockwise for less fuel.
Sounds like you had it rich, and turned them out.
Try 2.5 in front, 2.5 in back, and screw in the front one if it is still too rich.
crowley1027 is offline
post #4 of 6 (permalink) Old 07-20-2015, 09:04 PM
stock exhaust... many people have had good luck with stock jetting and just an ear shave
michiganteddybear is offline
post #5 of 6 (permalink) Old 07-21-2015, 07:51 AM
What crowley said, you're enriching.
post #6 of 6 (permalink) Old 07-21-2015, 11:26 AM Thread Starter
DOH!
I thought backing the screw out was leaning it out. I'll reverse it and try.
Mike
2006 Vulcan 750
Ear Shaved
Re-jetted
TW200 Petcock
