Things to BOLO while swapping carbs... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 9 (permalink) Old 07-19-2015, 12:25 PM Thread Starter
Rookie Rider
Tried using 'search'...didn't receive answers I needed. Tried browsing the 'carb/fuel system' thread...came up empty.
Ordered used carbs from an unknown year of vn750. Carbs coming from San Diego. Unsure if I'll just swap out completely or take pieces from new, used set. BUT...if I decide to swap out, what do I need to pay attention to and be on the look out for? (Other than cleaning them while they're out.) Will jets be same size? If not, do I need to do that 're-jet' procedure? Floats need to be checked? I'm pretty non-mechanically inclined. And no, I haven't bought a Clymer's manual yet. That's next.
Sakibomb750 is offline
post #2 of 9 (permalink) Old 07-19-2015, 03:33 PM
Mike DeAngelo's Avatar
Well at least you didn't buy the Haynes manual first like I did. The Clymer is much better and what I've found is while the information you receive here can point you in the right direction, nothing will take the place of that manual. If the manual reads like Chinese, don't worry, there are members here who speak it. I switched out the clutch plates on my 750 and received great pointers here but the manual was a great guide.
2008 Vulcan 900 Classic LT
HID lighting 35 Watt White
Chrome Slotted oval Mirrors
Chilhowee Tank Bra
Barons Big Air Kit
Vance & Hines Twin Slash staggered
EJK Gen 3 Electronic Jet Kit
1991 Vulcan 750 226 miles
Spiegler brake lines
rebuilt calipers, master brake cylinder
Mike DeAngelo is offline
post #3 of 9 (permalink) Old 07-19-2015, 04:24 PM Thread Starter
Rookie Rider
Mike, thanks for the input. Haven't seen many people mention the Haynes manual. But, you left out any input that I actually needed. Haha Now, judging by your posts in several other threads...I know you have some knowledge somewhere hidden inside that noggin.
post #4 of 9 (permalink) Old 07-19-2015, 04:39 PM
Here is a chart of the carb jets of the different models of the VN750. This was taken from the online service manual...
http://www.tocmanufacturing.com/File...nd%20Parts.pdf
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #5 of 9 (permalink) Old 07-19-2015, 09:59 PM
I'm just a squirrel in the woods looking for some nuts...I'm yelling charge with saber in the air running backwards away from the fight.
I'm a novice at best. . Experienced...no. I'd call it lucky. Still, I hate to see people suffer through things. But that being said, You need to get a hold of that Clymer repair manual not the online manual even though it may be some help to you.
Chilhowee Tank Bra
Barons Big Air Kit
post #6 of 9 (permalink) Old 07-19-2015, 10:06 PM
Sometimes I'm a nut in the woods looking for a squirrel
post #7 of 9 (permalink) Old 07-19-2015, 10:34 PM
I hear they are good eating Doc.
Chilhowee Tank Bra
Barons Big Air Kit
post #8 of 9 (permalink) Old 07-20-2015, 07:48 AM
Make awesome soup
post #9 of 9 (permalink) Old 07-20-2015, 09:07 AM Thread Starter
Rookie Rider
Wishing I had picked it up a month ago now! Carbs will be here today. Should probably just take them to a machine shop and have them cleaned, then install, and run Sea Foam through the tank a couple times. Assuming nothing else is wrong...
