Carb adjustment - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 07-11-2015, 02:14 PM Thread Starter
Carb adjustment
Sorry guys I know I have written about this before but I can't find the thread.
I believe I need to allow a little more air in the rear carb as that spark plug is a little black. The front is seeming to be burning good.
So what I am hearing is to turn the adjustment in instead of out? Please confirm this before I got tinkering with it.
Grace and Peace to you!
Richard
mrseedsower is offline
post #2 of 4 (permalink) Old 07-11-2015, 02:42 PM
Check you air filter for that cylinder first. As it starts to clog, the cylinder will develop a rich condition. The air mixture screws only effect the idle circuit. If you still want to try adjusting the screw, turn it in 1/4 turn at a time and try it. To check the plugs correctly, you have to have the engine warmed, run the rpms up around 4,000, then shut off the engine and hold the throttle open until the engine stops. Then you will get the best plug color. If the plugs are still black, dirty air filter or 2 big of a main jet.
Just my 0.02.
'99 VN750, all stock
performed driveshaft maintenance
checked the ACCT using the Grambo Trick
Sycned carbs with flow meter
Yuasa YTX14AHL-BS AGM Battery
NGK DPR7EIX-9 Irridium Spark Plugs
vulcan1999 is offline
post #3 of 4 (permalink) Old 07-11-2015, 03:11 PM Thread Starter
In or out?
Richard
post #4 of 4 (permalink) Old 07-11-2015, 03:19 PM Thread Starter
sorry I just saw the answer
Richard
