Backfiring like mad - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 18 (permalink) Old 07-05-2015, 04:07 PM Thread Starter
Backfiring like mad
bike backfires like crazy now. Is that common after doing th ear shave? Also stalled out just sitting in traffic before. Anyone know if I'm running to rich or not?
post #2 of 18 (permalink) Old 07-05-2015, 07:27 PM
I'd check the ports that need plugged are. Backfiring while deaccelerating, or always?
smltownr is offline
post #3 of 18 (permalink) Old 07-05-2015, 07:38 PM Thread Starter
While decelerating. Also pops loud when starting.
post #4 of 18 (permalink) Old 07-05-2015, 07:43 PM
Original exhaust? Check for carb boot leaks.
smltownr is offline
post #5 of 18 (permalink) Old 07-05-2015, 07:53 PM Thread Starter
Yea original exhaust. I'll check the carb boots. I had a problem of it dying while riding too. Thinking its poogs but I need to find a way to stop it haha. I have a charity ride in 2 weeks
post #6 of 18 (permalink) Old 07-06-2015, 07:59 PM Thread Starter
Any other help?
post #7 of 18 (permalink) Old 07-06-2015, 08:38 PM
It sounds like something is definitely wrong; it shouldn't be backfiring when starting nor dying at lights.
I always have issues backfiring when starting when my battery is weak; make sure that isn't the case just for giggles. Check your charging system and make sure it's working properly. Dying at lights could also mean you aren't charging enough, and voltage drops too low. You should see near 14v @ 5000rpm with a DC multimeter.
Pull your spark plugs; are they wet with gas, white and dry, etc?
Let's also get some more details on how you did your earshave. What pod filters, what jet sizes, what elevation are you at, etc.
If you feel it's poogs, pop the gas cap when you're having issues. Do you hear a hiss or noise like it may have been under pressure/etc? If so, perform the steps to clean the vent lines in the tank/cap.
post #8 of 18 (permalink) Old 07-07-2015, 12:11 AM Thread Starter
Bike fires up every time without a problem so I don't think the charging system is to blame. And the ear shave I did is http://06vn750.blogspot.com/2011/05/...ormat.html?m=1 . So my jets are 142-42.
post #9 of 18 (permalink) Old 07-07-2015, 12:15 AM Thread Starter
Wish I could just afford a damn mechanic. Really thinking about selling her. My truck and bike are both constantly having issues.
post #10 of 18 (permalink) Old 07-07-2015, 12:45 AM
Check out the other stuff. pull the plugs, are they wet with gas? Could be a stuck float or something.
