Just isnt running right... - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 20 (permalink) Old 07-02-2015, 07:01 PM Thread Starter
Dirt to road
duraholiday's Avatar
I finally got my bike on the road yesterday but only for about 40 mins until it just died due to a dead battery, my bikes not charging the battery but thats a different issue im working out atm. Anyway... I need some help trouble shooting some issues, so please read the following list and help if you can please.
Note:I have done the ear shave and coaster mod. I have not changed the jets from stock. I have completely tore down and cleaned the carb, ran sea foam and cleaned the gas tank. That said
  • Takes a while to idle down after throttle is given, stuck rpm
  • Backfires constantly, especially in idle
  • Random rpm boost and acceleration when riding at constant speeds
  • Any time giving it more then 3/4 throttle when in gear it hesitates and the rpm doesnt increase like its choking on to much air or fuel.
any help would be much appreciated,
Thanks
-Holiday
Project Bike 92 VN750
Days running: 0
Project Pictures http://s1116.photobucket.com/user/dieinghost/library/
Up coming Projects:
NOW- Getting it running....
Winter of 2015- Bobber Build
duraholiday is offline
post #2 of 20 (permalink) Old 07-02-2015, 08:51 PM
What air filters are you using?
post #3 of 20 (permalink) Old 07-02-2015, 09:15 PM
What exhaust also?might need to rejet.have you popped out the seals on the air mixture screws and what are they set at?
post #4 of 20 (permalink) Old 07-02-2015, 09:32 PM Thread Starter
Dirt to road
k&n pod filters and stock exhaust. Doc i set the mixture screws to 2 1/4 turns out.
Days running: 0
Up coming Projects:
post #5 of 20 (permalink) Old 07-02-2015, 09:44 PM
Check your throttle cables
post #6 of 20 (permalink) Old 07-02-2015, 10:04 PM
Experiment with the air screws. Turn them out a little bit at a time and do a run.
post #7 of 20 (permalink) Old 07-02-2015, 10:10 PM
Also check for air leaks around the carbs.
post #8 of 20 (permalink) Old 07-03-2015, 01:06 AM
X2 air leaks in boots. Spray starting fluid while idle. To me all four symthoms, sounds like running lean.
smltownr is offline
post #9 of 20 (permalink) Old 07-03-2015, 02:14 AM Thread Starter
Dirt to road
Alright ill try some things tomorrow and see what i can find, thanks!
Days running: 0
Up coming Projects:
post #10 of 20 (permalink) Old 07-03-2015, 02:15 AM Thread Starter
Dirt to road
Spray starting fuild around the boots?
Days running: 0
Up coming Projects:
