FYI- carb cleaning with SeaFoam - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 12 (permalink) Old 06-21-2015, 10:31 AM Thread Starter
JM2001's Avatar
Did this 3 nights ago on an old KZ900 that wouldn't idle or run smooth.. Worked great. Same principle for a v twin.
https://www.youtube.com/watch?v=FonLaCVFMcU
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
post #2 of 12 (permalink) Old 06-22-2015, 08:51 AM
I owned a four carb bike once. You have to have a screw loose to own a bike with FOUR carburetors. wait...what... I was young so anyway. I'm still betting that you can find a suitable intake manifold to fit a single CV carb on the VN.
The sportster manifold
post #3 of 12 (permalink) Old 06-22-2015, 10:02 AM
I've got four bikes with four carbs...
post #4 of 12 (permalink) Old 06-22-2015, 05:09 PM Thread Starter
JM2001's Avatar
I've got two bikes with 4 carbs and wouldn't part with them.
JM2001
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
degoated
All LED lighting
JM2001 is offline
post #5 of 12 (permalink) Old 06-22-2015, 07:47 PM
Amen to that
post #6 of 12 (permalink) Old 06-22-2015, 11:13 PM
Goofy, I think the only way to get a single carb manifold is to fab it ourselves. When I was having my float adjust problems a couple of weeks ago, I was seriously considering this. When I had my carbs out, one of the 7 times that week, I took measurements and recorded angles of intakes. Drew up a few ideas. Seems the best would be like a extended plenum design. This would lower the velocity for most of the distance so it would lower the chance of icing in low temps. Thinking about a 38mm mikuni pumper jetted one size less than the 883 set-up. But I have worked out my carb problems so this is on the back burner.
smltownr is offline
post #7 of 12 (permalink) Old 06-22-2015, 11:22 PM
Someone on here did it...
post #8 of 12 (permalink) Old 06-22-2015, 11:24 PM
ODD, fabricated or pvc or plumbing parts?
smltownr is offline
post #9 of 12 (permalink) Old 06-22-2015, 11:38 PM
Think it was fabricated, I'll have to search for it
post #10 of 12 (permalink) Old 06-22-2015, 11:47 PM
Only way to go. Stainless with butt welded components.
smltownr is offline
