High idle after long hot ride. - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 13 (permalink) Old 06-16-2008, 10:49 AM Thread Starter
Dedicated Rider
sgsibob's Avatar
Set idle at 1100 RPM in town with bike warmed up. Then after a prolonged ride at 60-80 mph in the desert the bike returns to idle at 1500 RPM. If I reset the idle back to 1100 while the bike is still hot it will be too low when I start it the next day. Is this normal?
2003
Chrome crash bar
Mustang seat
LeatherLike hard bags
Sissy Bar riser
Memphis Shades Malibu shield
in gradient black
7K as of 6/08
Paid for with the
Rebel 450 above
sgsibob is offline
post #2 of 13 (permalink) Old 06-16-2008, 11:24 AM
Calif Rider
weh44att's Avatar
Yes my bike does the same. It seems to take the bike good time to really warm up. My bike is a 04, and does the same. After about 10 minutes of riding I have to reset the idle down again. Yes then the nest day or the nest time I starte it I will reset idle for restart. I have marked the knob with paint to for first start of day then turn it down as needed. Ride safe.
2004 25,500 miles
Led tail light enhancement
Homemade floor boards
Headlight modulator
Extra heat sink on R+R
R+R relocation
Homemade driver's backrest
Fused Stator
Mcct conversion-cost 4.50
Ride-on in tires
iridium plugs
coil pickups adjusted.
weh44att is offline
post #3 of 13 (permalink) Old 06-16-2008, 11:37 AM
I usually re-adjust the idle on mine once really warmed up too.
post #4 of 13 (permalink) Old 06-16-2008, 02:14 PM
liljd's Avatar
Nopey it's not normal, well it is if you need to clean the carbs. What it's doing is starting the flooding problem but may not be that bad to notice yet just the idle. Mine did that till I cleaned my carbs good.
James
1985 vn700 (T'Plana)
Gremlin bell
HD-O shield
saddlebagged
custom made supports
tool bag
extended backrest
Protac backrest
Highway pegs
custom mirrors
custom grips
V&H cruisers
lever covers
DieHard AGM
Kuryakin battery gauge
and LED taillights
marbled
____________________
VROC #27169
Tn VROC #134
www.youtube.com/thetrueliljd
liljd is offline
post #5 of 13 (permalink) Old 06-16-2008, 03:04 PM
Just thinking...... are you changing elevations much when this happens?
post #6 of 13 (permalink) Old 06-16-2008, 04:06 PM
Daily rider
ksmnet's Avatar
I was having trouble getting mine to idle well until warmed up. I don't like changing the idle speed back and forth. After I coastered it, I have much less trouble. It will idle fine after a minute or two now.
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
post #7 of 13 (permalink) Old 06-16-2008, 04:39 PM Thread Starter
Dedicated Rider
sgsibob's Avatar
Re elevation changes, no, not a whole lot. It seems to be more related to heat. (The bike is not coastered) The first time I noticed it I started out at 2400 ft and about 90 degrees, dry heat, ended up at 4800 ft in the 80s, no problem. Later that day back to 2400 ft again but temperatures in 100s, and had the high idle. Last weekend I started out at 2400 ft and went over several 7,000 ft summits, ended up at 6,500 ft with no problem. Rode around at 6,500 ft to 8,000 ft and noticed a little decline in performance due to the elevation but no issues with idle speed. When I retraced my steps again I was running for about 80 miles in temperatures above 105, and had the high idle. So there's no correlation with anything but heat.
2003
Chrome crash bar
Mustang seat
Sissy Bar riser
in gradient black
7K as of 6/08
Paid for with the
Rebel 450 above
sgsibob is offline
post #8 of 13 (permalink) Old 06-16-2008, 05:52 PM
I had the same problem and I did a good carb clean and it has not done it since. That's what I would reccomend. My problem was almost identical.
buckman is offline
post #9 of 13 (permalink) Old 06-16-2008, 06:35 PM
Vulcaneyez's Avatar
Hmmm, my '03 idles a constant 1,100 to 1,200 regardless of weather.
Vulcaneyez
Vulcaneyez is offline
post #10 of 13 (permalink) Old 06-16-2008, 09:34 PM
kay
carbon unit
kay's Avatar
My 94 does too, once it's warmed up.
My RE does have a idle thats way high once it's fully warmed.
But we've not got it jetted properly yet. Still bit to rich.
2010 Triumph Speedmaster
1995 Vulcan750
1989 XT350
M880
1959 M38A1
kay is offline
