New Vulcan Owner. Fuel, or battery? - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 10 (permalink) Old 06-06-2015, 02:50 PM Thread Starter
VulcanMatt's Avatar
I just bought my first motorcycle from a family member. It's the 1992 Vulcan 750. After riding once, I noticed it had a leak in one of the fuel hoses coming off the petcock.
I took off the seat, tank and then removed the two black hoses connected to the tank (the clear line looked fine so I left it alone).
I took the two hoses to Advance Auto and got some replacement hose. I cut the hoses to the correct length and installed the two hoses.
After cleanup I tried starting the bike but no luck. It would turn over when ignition was pressed, but not fire.
After a few tries, the battery had died down and was just clicking. I put it on a trickle charger overnight.
The next morning it fired up, but acted like it was a struggle to stay on. If I let it idle in neutral it will stay on, but after idling without throttle, when I roll on the throttle it dies immediately.
The fuel is in the "on" position. It has fuel in it. It's wierd that it fires up after the battery charges but then acts like it cannot stat on.
Thanks for the advice in advance. I'm happy to be a Vulcan owner.
VulcanMatt is offline
post #2 of 10 (permalink) Old 06-06-2015, 03:14 PM
Competent Noob
What's your idle speed? Mine gave me a bit of grief after it warmed up so i raised the idle to about 1100 and now its fine.
1995 Vulcan 750
Purchased 5/3/2015 w 10,600 miles
No mods I'm aware of
DieselPlower is offline
post #3 of 10 (permalink) Old 06-06-2015, 04:05 PM
Hey Matt how about an introduction in the Newbie section?
post #4 of 10 (permalink) Old 06-06-2015, 05:13 PM Thread Starter
VulcanMatt's Avatar
Diesel...thanks for the suggestion. How do I raise the idle speed?
Oledirty...I'll have to do that. Thanks.
post #5 of 10 (permalink) Old 06-06-2015, 05:15 PM
Thank you,Matt.there is a black knob on the carbs
post #6 of 10 (permalink) Old 06-06-2015, 05:16 PM
Competent Noob
While on the bike look down in front of your left leg. You should see a round black nob. Give it a turn. Don't remember which way but youll figure it out quick.
1995 Vulcan 750
post #7 of 10 (permalink) Old 06-06-2015, 06:48 PM
Yup.thar she be
post #8 of 10 (permalink) Old 06-06-2015, 09:19 PM Thread Starter
VulcanMatt's Avatar
Thanks. I'll check it out in the morning and report the results.
post #9 of 10 (permalink) Old 06-07-2015, 08:54 AM
Do you use the choke when cold starting it?
post #10 of 10 (permalink) Old 06-07-2015, 09:57 AM
Shouldn't run off the battery once it's fired up check your charging system and make sure u have good spark then it's probably fuel if those are good
Thatguy32 is offline
