Help! hard to start Barely runs now - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 14 (permalink) Old 06-10-2008, 12:37 PM Thread Starter
Well installing the stock airbox and ears was a giant step backwards! The bike spits and sputters. Will only run if the throttle is kept about 1/3 to open and constantly twisted back and forth. Will not idle. Did my shooting carb cleaner up the drain blown out something or dislodge goo that now is stopping up something? I took the just installed ear covers and elements off to see if any effect, no change. I do see plastic caps covering vacum ports for the removed surge tank stuff. Could the PO have changed the mixture settings? I get the location from looking at photos in other threads. I also found a comment that says the mixture screws are factory set at 1 5/8 turn. I think i'll see what they are set at and reset at this spec and try again to start. I have ordered a Clymers but right now you guys and the foggy on line manual is the only reference I have. Thanks for the help so far and please keep it up.
3z
jmczzz is offline
post #2 of 14 (permalink) Old 06-10-2008, 12:40 PM
If the PO had done the ear shave, they probably changed the jets too. You'll need to pull the carbs and go back to stock jets.
post #3 of 14 (permalink) Old 06-10-2008, 12:58 PM Thread Starter
I checked the jet on the front carb it is a 132 which i understand is stock. i did use a couple of gals of fresh gas and added about 3 oz of seaform. do I need to drain that out?
jmczzz is offline
post #4 of 14 (permalink) Old 06-10-2008, 02:07 PM
That is the right main jet. There is also a Pilot jet which if I remeber right should be a 32 and a needle jet which should have no shims.
More than likely he did change the Air/Fuel mixture.
What you are describing sounds like a clogged pilot jet. The seafoam may clear it out with time.
JamieB is offline
post #5 of 14 (permalink) Old 06-10-2008, 04:05 PM
one2's Avatar
I was at our local American Auto parts store and talked to the Seafoam jobber guy when I picked up a can and asked how much was too much to mix in a tank of gas. He said use the whole can. I told him I had a motorcycle and it only held about 3 gallons of gas. He said it wouldn't hurt anything if I used the whole can and in fact I could run straight Seafoam like gas if I wanted to. So I dumped the whole can in...and no problem...done it twice now.
I'm not recommending anything here, just reporting what I was told and did. Kinda bet my carbs are real clean though. But if I thought I had a super clogged carb I'd probably use the whole can.
one2 is offline
post #6 of 14 (permalink) Old 06-10-2008, 05:20 PM Thread Starter
I've been slowly adjusting the mixture screw on both carbs after screwing them in from 2 & 2 1/2 turns. I started by setting them both at 1 1/2 out and have moved them out to 1 3/4 and 2 out. Now it runs pretty smooth at 2 to 5 k rpms but still will not idle. Also will not rev above 5 k unless I snap the trottle down then back up quickly then it goes to about 7 but back fires from the rear cylinder and stalls back down to 5 k. I will pour the whole can of seafoam in the tank. I also believe I have a charging issue, but that will be a new thread.
thanks for the ideas and any more will be welcomed. 3z
jmczzz is offline
post #7 of 14 (permalink) Old 06-11-2008, 07:45 AM
one2's Avatar
When my stator wires burnt, before I knew they did and my battery wasn't charging, I was riding home and noticed at 7K my engine began cutting out rather badly. That was because the battery was getting weak and couldn't handle the high RPMs...or so I determined. Overnight I fully charged the battery and there was no missing at the higher RPMs the next day.
one2 is offline
post #8 of 14 (permalink) Old 06-11-2008, 10:10 AM
Have you checked the choke cable to be sure it's working right?
post #9 of 14 (permalink) Old 06-11-2008, 01:01 PM
Daily rider
ksmnet's Avatar
Excuse me for asking this, but do you guys think you are riding crotch rockets? Maybe I'm just becoming an old fuddydud, but I cringe when I get over 4k while riding. I watch the tach periodically, but have always been one to go by sound more than anything for shifting (call me old school). I mean, I realize redline is at 9k, but I can't imagine that it's too great on the engine to run high revs all the time - not to mention the loss in fuel economy. Am I all wet here?
2017 Indian Roadmaster (current ride)
2003 VN1600A (Traded August 2017 to #1 son for a Bushmaster AR)
2001 VN750 bought 4/19/08 w/2309 miles(Sold April 2010 with just over 12,000 miles)
VROC #33035
__________________________________________________ ________________
Just when I thought I was winning the rat race, somebody moved the finish line!
ksmnet is offline
post #10 of 14 (permalink) Old 06-11-2008, 06:42 PM Thread Starter
heck no, the last time I actually rode a bike at 7k rpm was 15 yrs ago and was on a flat hwy in west North Dakota. Nobody around for several hundred miles.
What this is about is trying to get my 89 project bike in resonable tune so I can ride it some while Im rehabing it. 3z
jmczzz is offline
