Won't Idle - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 4 (permalink) Old 06-10-2008, 08:04 AM Thread Starter
Unhappy Won't Idle
Hi Folks,
I have a '99 750 that was left over winter with about 1/2 gal of untreated gas in it. It won't idle and won't run w/o the choke on full. I tried seafoam and thought I was making progress but when I tried to ride it, it stalled when I pulled up the kickstand and raised it to a riding position. Any suggestions?
P.S. I've never taken a caarb apart and am afraid to do it; should I be?
Paulb750 is offline
post #2 of 4 (permalink) Old 06-10-2008, 11:08 AM
ChrisC's Avatar
My guess is that the idle (pilot) jet is varnished from the old gas. If the Seafoam doesn't work, you can try filling it with carb cleaner. There is a thread here that explains how to use the carb drain. I don't have the link, but a quick search ought to turn it up. Barring that, removing and giving the carbs a good soak in solvent is probably warranted. I was just at the same place you are in now. In my case the Seafoam did the trick. I was reluctant to pull the carbs, however, since I have been doing a lot of work on my bike, I am leaning towards pulling them in a couple of weeks to give them a thorough cleaning. Just my $.02! The more experienced folks will chime in I am sure. BTW...If you don't already have one, pick up the service manual. I have the Clymer's manual, and it has been invaluable. Also, there is a downloadable Kaw service manual in PDF format at www.tocmanufacturing.com. It's not a bad idea to have both around. Good Luck!
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-De-Goated/Re-goated
-Coastered
-Splines Lubed
-Stebel Nautilus Horn
-AutoMeter 2" VOM
-Silverstar Headlight
-Plexifairing III
ChrisC is offline
post #3 of 4 (permalink) Old 06-10-2008, 04:28 PM
ChrisC's Avatar
Here is the link to the service manual (WARNING: It's about 115MB!):
http://www.tocmanufacturing.com/File...nd%20Parts.pdf
Chris
Wayne, NJ
1989 VN750-A5
VROC #27781
-MF Battery
-Coastered
-Splines Lubed
-AutoMeter 2" VOM
-Plexifairing III
ChrisC is offline
post #4 of 4 (permalink) Old 06-10-2008, 06:34 PM
I have a ? for Paulb750. When you put up the kickstand did you have your bike in gear?
buckman is offline
