muffler removal - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 6 (permalink) Old 05-30-2008, 06:11 PM Thread Starter
Send a message via AIM to Joey750
muffler removal
So i just removed the muffler from between the two pipes and replaced the gap with two straight pipes of equal diameter of the pipe coming off the cylinders. It sounds fantastic however hesitates. What do i need to do?? to the carbs/jets? Air intake??
Joey
Joey750 is offline
post #2 of 6 (permalink) Old 05-30-2008, 06:19 PM
Sky Rider's Avatar
Since you have changed the dynamics of the exhaust, you will need to rejet the carbs. That much I do know. What size jets is for someone else to answer.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
New R/R, Installed 14Jun08
New Stator installed 10 Jun08
21480 Miles
VROC #8542
Sky Rider is offline
post #3 of 6 (permalink) Old 05-30-2008, 11:59 PM
On His Lady Vulcan
wkrizan's Avatar
I don't believe he will need to rejet, adjust his idle mixture screws to about 2 1/2 turns out yes but not rejet unless I am missing something.
Peace
Pictures of the "Ladies"
wkrizan is offline
post #4 of 6 (permalink) Old 05-31-2008, 12:08 AM
Sky Rider's Avatar
Unless I am mistaken, which is a possibility, this is just about the same as degoating which requires a rejet AFAIK. In taking the mufflers out of the equation, you've taken away the back pressure the mufflers create. This changes the air fuel mix and not just at idle which the only thing the air mix screws adjust. It changes it at all RPMs, and therefore he may need to rejet.
Jim W
93 VN 750 "Ursula"
Moved R/R 08Sep06
R/R rewire 17Feb07
21480 Miles
VROC #8542
post #5 of 6 (permalink) Old 05-31-2008, 09:21 AM
What you need to do is add a crossover pipe. The crossover pipe will allow the exhaust to "equalize. This is commonly refered to as an H pipe, any local welding shop can fab one up. A benefit will probably be smoother running and more high end power. Keep in mind that low end power loss has been reported after GB removal.
Rckmtn
Dennis Huff
Cheyenne, Wy.
05 VN 750
Spitfire windshield
self canx turnsignals
Jardine 2 into 2
Luggage rack
Extended passenger backrest
KURYAKYN LED voltmeter
130 DB horns
rckmtn is offline
post #6 of 6 (permalink) Old 05-31-2008, 09:30 AM
On His Lady Vulcan
wkrizan's Avatar
You could very well possibly be correct. (Anyone that 100% sure can pipe in anytime) I am mearly going by everything that I have read about installing aftermarket pipes and what is suggested to be done when doing so. Ear shaving I am aware in that proccedure required rejetting but pipes required adjustments of the air mixture screws.... One question asked and now I have one myself... Damn you MAN, thanks JOEY...lol
Peace
wkrizan is offline
