Dumb question - Kawasaki Vulcan 750 Forum : Kawasaki VN750 Forums
post #1 of 16 (permalink) Old 05-02-2015, 06:34 PM Thread Starter
Dirt to road
duraholiday's Avatar
Dumb question
Is there 2 throttle cables?.... if so wheres the other one go?
Project Bike 92 VN750
Days running: 0
Project Pictures http://s1116.photobucket.com/user/dieinghost/library/
Up coming Projects:
NOW- Getting it running....
Winter of 2015- Bobber Build
duraholiday is offline
post #2 of 16 (permalink) Old 05-02-2015, 06:36 PM Thread Starter
Dirt to road
Second pic
Days running: 0
Up coming Projects:
post #3 of 16 (permalink) Old 05-02-2015, 06:38 PM
There are two cables from your throttle grip.....one thortle, one return throtle .
Hope this helps
WilliamTech
post #4 of 16 (permalink) Old 05-02-2015, 06:45 PM
yes, there are 2 cables.. one to pull when opening, and one to pull when closing (push/pull arrangement).
the 2nd cable goes into the 1/2 circle part behind the one you have installed.. connects to the same part as the cable you have attached, but directly opposite it (hidden behind carb)
michiganteddybear is offline
post #5 of 16 (permalink) Old 05-02-2015, 07:12 PM
2000 VN 750 Senior Member
Hope this helps
WilliamTech
OK.....I think I understand but..... one thortle and two throtles. lol
Tom
Vulcan 2000
4507 miles
Vulcan2000 is offline
post #6 of 16 (permalink) Old 05-02-2015, 07:24 PM
....ONE throttle, ONE return Throttle !
post #7 of 16 (permalink) Old 05-03-2015, 11:01 AM Thread Starter
Dirt to road
Now i see. I put my carb back in yesterday and i seen there was 2 cables but i couldnt see where the 2nd one went.. also one of the cables rusted off inside the tube.... how do i tell which one goes where so i can order a new one...
Days running: 0
Up coming Projects:
post #8 of 16 (permalink) Old 05-03-2015, 02:08 PM
Just joking. I read your post three times and I laughed harder each time because I do the same thing if I don't reread my posts several times before hitting "submit" and then I still end up having to edit five minutes later. Just glad to see I am not he only one with backward fingers.
Tom
Vulcan 2000
4507 miles
post #9 of 16 (permalink) Old 05-03-2015, 02:29 PM
I have backward fingers on both my left hands
post #10 of 16 (permalink) Old 05-03-2015, 04:49 PM
JM2001's Avatar
The accelerator cable is shorter and has a cable guide attached to it. The decelerator cable is the closest cable towards you when sitting on the bike( at the throttle grip )
JM2001
" Loud Pipes Risk Rights "
2001 Vulcan 750
marbled
TOC upgrade on ACCT
rectifier relocated
iridiums
decals removed
upgraded mirrors
Pic up coil mod done
degoated
All LED lighting
Upgraded Mosfet rectifier
JM2001 is offline
